Driver's side door lock
Old 10-25-2005, 04:14 PM
ob1vette
Navigator
ob1vette's Avatar
Default Driver's side door lock
My driver side door lock only works manually. It will unlock with remote fob and by pressing unlock button on door. the dealer wants $600.00 to replace "door module". 99 roaster
Old 10-25-2005, 04:32 PM
screw991le
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Get a used one on ebay or from Gene from Karshop. DYI
Old 10-25-2005, 04:49 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
Wow list price on the part is 239.... install is less than an hour...
Dealer wants 360 for an hours work...That's freekin amazing
Old 10-25-2005, 08:55 PM
alanh
alanh's Avatar
You can cut a 3/8 square hole in the top center circut board ends of the relay's, which are located on the module circut board. The case is thin plastic and will cut easily with an exacto knife. This will expose the contacts for the solenoids.
Stick emery cloth inbetween the contacts, press the contact points closed with something small like a toothpick and pull the emery cloth out. A few times of this and the contacts will be clean. Tape the hole over and put everything back together. Mine's been working fine since the cleaning of the contact points.
ckreider33 (04-08-2024)
Old 10-25-2005, 09:04 PM
Lovin It!!! - C5
Support Corvetteforum!
Lovin It!!! - C5's Avatar
Wow! Awesome info!
Old 10-26-2005, 08:59 PM
RonJ
RonJ's Avatar
Hi Alan ..... good info. The picture doesn't show for me, just a red X. I tried to go right to your host .. get a forbidden message.
Could you please try to post it again or send me the pic???
Thanks .... RonJ ...
Old 10-26-2005, 09:43 PM
feeder82
feeder82's Avatar
I have seen a bunch of posts on this issue, my 02 is doing the same thing, these modules must be very failure prone. a couple of the other posts suggested a weak battery. the drill out tip sounds like one to try
BUT I HATE REMOVING DOOR PANELS, I have never pulled 1 without busting a couple of clips. and yes i use the little flat tool
Old 10-26-2005, 10:22 PM
alanh
alanh's Avatar
Old 10-26-2005, 10:33 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
i like it, very nice fix
Old 10-26-2005, 10:36 PM
SteveDoten
SteveDoten's Avatar
so it won't LOCK when you hit the lock button? this is my problem also on my 99frc, the fob locks and unlocks and the pass switch will lock, but the lock button on the drivers switch does nothing
Old 10-26-2005, 10:45 PM
alanh
alanh's Avatar
A little additional information on the relay's would be helpful. There is one relay to pull the solenoid down to lock the door. There is a second relay that reverses the polarity and pulls the solenoid up to unlock the door. The solenoid pulls quite a bit of current and creates a significant electrical arc across the contact points each time the relay is activated. This large arc can leave a carbon deposit on the contacts that will sometimes insulate the contacts from each other, resulting in a locking or unlocking action that will no longer work. A few strokes of the emry cloth, on both contacts, will usually clean the deposits away and every thing will work normally.
Old 10-27-2005, 09:48 PM
RonJ
RonJ's Avatar
Many thanks for the pics Alan!!!
Another task to do over the winter!!!
RonJ ...
Old 10-28-2005, 12:31 PM
chuck1026
chuck1026's Avatar
Cruise-In II Veteran
Great pictures!
Is there any way to modify the circuit to prevent this arcing? My D/S module has advanced from unlock to both unlock and lock being intermittent .
Old 11-02-2005, 12:13 AM
SteveDoten
SteveDoten's Avatar
this thread is saving people hundreds of dollars in door control modules every week
Old 11-02-2005, 12:49 AM
bindy
bindy's Avatar
Default Here's the fix
I have had several of these door control modules go "bad" on my '01 and '02. After reading others posts regarding failure, I decided to tear one apart to see for myself what goes wrong. Here's a picture of the passenger side relay (ripped open) for the door lock that stopped working - just as suspected - BURNT CONTACTS!!!
Here's a direct 12 volt - 5 pin replacement relay with the exact same external dimensions. A little solder wick and a soldering iron and they come out very easily. Should take less than an hour to do, including removing the door panel.
Look at the invoice from Digi-Key for the part number - only $1.30 each (plus shipping of course).
Old 11-02-2005, 09:54 AM
SteveDoten
SteveDoten's Avatar
bindy just made the thread even better, NICE FIX!! 11.50!! beats the deductible at the dealer or the couple hundred for a new door module
Old 11-02-2005, 11:41 AM
bindy
bindy's Avatar
I tore one open several months ago and filed the contacts, but unfortuantely that fix didn't last long. After finding the correct sized part, it was a no brainer to just replace it
To Driver's side door lock
Old 11-09-2005, 12:57 PM
jbvmag
4th Gear
jbvmag's Avatar
Default Awesome Info!
This forum ROCKS! Thanks to all who take the time and pics to share all this info.
Old 11-09-2005, 07:07 PM
ptiller
ptiller's Avatar
Excellent Thread!!!
In the pics, the lock-relay looks different in size/shape from the unlock relay. Are these same spec relays? I can not make out the part marking on the unlock relay. I would like to replace both, so I am looking for a make and part number for the unlocking relay or a good sub.
Also, any details on replacing (make & part number, a sub is welcome too ) the relays that control the windows (up / down ). If we can get these three items, It would make this thread a definite sticky!!!
Old 11-09-2005, 08:36 PM
alanh
alanh's Avatar
Both relay's are the same. In my picture, the unlocking relay has electrical tape over it and the locking relay hasn't been taped over yet.
Quick Reply: Driver's side door lock
