Help Crack NAV Screen Diag PIN Code
Old 10-07-2005, 04:19 PM
abrimberry
abrimberry's Avatar
Cruise-In II Veteran
Default Help Crack NAV Screen Diag PIN Code
Original Thread, check out posts #16 and #38
http://forums.corvetteforum.com/show...p?p=1552330666
Quote from above thread:
There is also a debug/diag screen you can access by holding your finger on a point at the top of the screen. after 5 seconds, a virtual keypad comes up and depending on what code you enter, settings are visable/open to change. for example, one code will let you only view most of the settings, another will let you view all of the settings, and still a third will let you start changing the settings. i asked the engineer if there was a way to turn off the lockout feature this way and he replied no. I also asked about MP3 playback and some sources being louder than others. His response was that the levals of the sources were set in the compiled software and the mp3 playback capability will be comming soon.
Sign up here for your block of numbers.
1000 - 1099 Buffy
1100 - 1199 abrimberry
Last edited by abrimberry; 10-07-2005 at 04:25 PM. Reason: Added quote from previous thread
abrimberry is offline
Old 10-07-2005, 05:35 PM
ein Tier
ein Tier's Avatar
Location: Austin, Texas Codes 660, 9448, and 295660 work in the C6 navigation unit. No DVD playback yet.
I checked the one and two digit codes, including 01-09, so you can mark those out.
ein Tier is offline
Old 10-08-2005, 09:36 AM
matty98ws6
matty98ws6's Avatar
Ttt
matty98ws6 is offline
Old 10-08-2005, 10:38 AM
Jay13
Jay13's Avatar
Location: . [Rotorhead] "You seem to be a douche. What I'm getting at is just STFU" [/Rotorhead]
St. Jude Donor '06 & '09 & '11
Found this Clicky by searching "GM Nav PIN" on yahoo. Somebody want to try it?
Jay13 is offline
Old 10-08-2005, 12:08 PM
AMF
AMF's Avatar
ttt
AMF is offline
Old 10-08-2005, 04:50 PM
Buffy
Buffy's Avatar
Checked 1000 - 1099, 1200-1299 and 1300-1399 with no hits. I'm doing 1400 - 1499 next.
Buffy is offline
Old 10-08-2005, 05:08 PM
Brett Hunter
Brett Hunter's Avatar
Tried 1971 and 1791, no luck.
Brett Hunter is offline
Old 10-08-2005, 05:43 PM
AC54ME
Support Corvetteforum!
AC54ME's Avatar
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Here is what that site says:
"I have a DTS but the nav system is essentialy identical. I know you all have had the 1791 code for a while. This one allows you to play the DVD while in drive. I have another code, and I didn't think anyone would be too interested in it, but since the 1791 code is so popular I figured I'd share it. This provides access to the general diagnostic features of the nav system. You can see satellite signal info, all the nav systems inputs, do tests of the mic and speakers, check software version, etc etc. There are several calibrations that you can make, and I suggest you avoid these unless you know what you're doing. I hope I'm not opening pandora's box here: 1971 (yes, very similar to the other code.) Have fun."
Scott
PS: the system is by denso and is virtually identical to one used by lexus. This might help in finding more codes for it.
AC54ME is offline
Old 10-08-2005, 07:24 PM
BIGGGIE
BIGGGIE's Avatar
St. Jude Donor '05-'06-'07-'08
Still looking for that spot...Where is it?
BIGGGIE is offline
Old 10-09-2005, 08:00 AM
connor
connor's Avatar
[QUOTE=There is also a debug/diag screen you can access by holding your finger on a point at the top of the screen. after 5 seconds, a virtual keypad comes up[/QUOTE]
On what menu do you try this and where on the screen, I tried it on my Nav screen but could not find it.
connor is offline
Old 10-09-2005, 09:00 AM
Ginny C6
Ginny C6's Avatar
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Aren't we all! Seriously though, I tried to find it on my Nav screen yesterday, and couldn't find it either. Thanks, Kevin
Ginny C6 is offline
Old 10-09-2005, 09:29 AM
BRCC
BRCC's Avatar
[QUOTE=connor]
Originally Posted by There is also a debug/diag screen you can access by holding your finger on a point at the top of the screen. after 5 seconds, a virtual keypad comes up[/QUOTE
[OUOTE]On what menu do you try this and where on the screen, I tried it on my Nav screen but could not find it.
On the map screen select MENU, you will get the menu screen with the 4 major boxes. Just above them top center/right there will be some yellow letters. Put your finger just to the right of the yellow letters in the blank space and apply pressure for about 5 sec's and the key pad will come up.
BRCC is offline
Old 10-09-2005, 10:09 AM
burtonbl103
burtonbl103's Avatar
St. Jude Donor '06-'07-'08 & '12-'13
I am still trying codes as well !
burtonbl103 is offline
Old 10-09-2005, 12:26 PM
anothercrisis
anothercrisis's Avatar
Found the screen. I will try a block of numbers as well. In my mind though, I would think that the pin might be related to the car or to the nav unit's serial number. Anyone gone there yet?
Jim
anothercrisis is offline
Old 10-09-2005, 01:34 PM
Nel727
Nel727's Avatar
In the same thread some posters reported that "1971" didn't do anything, so don't be surprised if it doesn't work.
Nel727 is offline
Old 10-09-2005, 08:38 PM
ricatthebeach
ricatthebeach's Avatar
I'm a little confused. Found the screen where you are asked to enter a pin code. If I enter Code #1791, will I be able to play a DVD in the Nav DVD slot and while moving? Please advise.
ricatthebeach is offline
Old 10-09-2005, 08:40 PM
BIG Dave
BIG Dave's Avatar
Received 4,684 Likes on 1,862 Posts
I wish! It did nothing when I tried it except return me to the MENU screen.
BIG Dave is offline
To Help Crack NAV Screen Diag PIN Code
Old 10-10-2005, 06:52 AM
connor
connor's Avatar
Thanks, clear explanation and now I have the screen!
connor is offline
Old 10-10-2005, 09:19 AM
BRCC
BRCC's Avatar
First and formost we need to find the CODE. I do not think you will enable the playing of DVD movies with this function. When we find the code then we will know what this diagnostic screen displays, and what if anything we can do with it. Until then we are all flying blind.
BRCC is offline
Old 10-10-2005, 10:29 AM
Buffy
Buffy's Avatar
Jim
I've tried the last 6 of my VIN, date, etc. Of course there are a fairly large number of combinations here. I'm inclined to think it probably doesn't have anything to do with the car, as you might well need the diagnostics when installing a new unit in a car and if it had to read the VIN to get the code and it had a problem reading the VIN and you couldn't get into the diagnostics to figure out the problem ... And the nav's serial number isn't obvious, if they planned on the tech having to take the nav out before accessing the diagnostic screen they could have just put a jumper plug on the back or something.
Well, okay, I've seen some stuff designed that way. Or not designed. But a fixed code still seems more likely.
Buffy is offline
Quick Reply: Help Crack NAV Screen Diag PIN Code
