C6 rear/differential 2005 to 2006 Changes.
Old 10-04-2005, 05:41 AM
tekhombre
tekhombre's Avatar
Default C6 rear/differential 2005 to 2006 Changes.
Here are a few changes between the 2005 and 2006 C6 rear diffs.
The pinion support is re enforced on the 2006 (left).
The speedo reluctor behind the ring gear on the 2005 (right) is now just a spacer on the 2006 (left), the sensor was relocated over the ring gear teeth.
The 2006 trans mounting has been widened and re enforced.
The 2006 housing has more webbing/support.
Both output shafts are splined into the side gears on the 2006.
The 2006 (bottom) output shaft is stronger, it's not narrowed after the splines like on the C5, and 2005 C6 (top).
HTH, Julio
Old 10-04-2005, 07:07 AM
Al Engel
Al Engel's Avatar
Default '06 Changes
Amazing - all those "hidden" changes, jut in the rear. I wonder what other changes have been made that were not part of the 'official' press release describing the '06 changes?
Old 10-04-2005, 09:21 AM
dollarbill
Support Corvetteforum!
dollarbill's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11
Great info Julio - I wonder if that change to add stregnth is to support the additional HP of the Z06? Or does the Z get a different center section?
Bill
Old 10-04-2005, 09:25 AM
The Garage Master
The Garage Master's Avatar
Wow I find that very interesting. I assume if we order the DTE or others it will be as strong and updated?
Old 10-04-2005, 09:47 AM
AMF
AMF's Avatar
Thanks for the info
Old 10-04-2005, 10:14 AM
1955 BelAir
Eccentric Member
1955 BelAir's Avatar
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
Were these running changes perhaps ??
Old 10-04-2005, 10:44 AM
Miaugi
Miaugi's Avatar
Bill
Old 10-04-2005, 11:23 AM
LS1LT1
LS1LT1's Avatar
There is another rear diff part number listed for 2006 so that very well could mean that the Z06 will be upgraded even further from this 'already stronger than 2005' unit....or it could just be a change for the new 2006 automatic models.
Originally Posted by 1955 BelAir
Were these running changes perhaps??
Possibly but I don't think so, it would've had to have been a very late 2005 change...there was a slight O ring/cover change within the 2005 run I think.
Old 10-04-2005, 12:29 PM
aaaaa
aaaaa's Avatar
Any idea what the Z51 uses?
Old 10-04-2005, 12:49 PM
SpinMonster
SpinMonster's Avatar
St. Jude Donor '08-'09-'10-'11
Bill
No, it was instituted to lower the value of my car and make tuners insist on giving you back the same garbage carrier you send in as a core since no one will want the crap 05 carrier.
Old 10-04-2005, 01:06 PM
LS1LT1
LS1LT1's Avatar
Same one, I'm thinking that all new 6 speeds (and maybe even automatics) will have the upgraded rear as pictured above.
Old 10-04-2005, 03:07 PM
dark_phantom
dark_phantom's Avatar
Location: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
Interesting.
Old 10-04-2005, 03:38 PM
DTE Powertrain
Collections Hold
DTE Powertrain's Avatar
Indeed they are. We have two of these differentials here also and we find it very interesting and gratifying that the very same component design changes, upgrades and refinements the manufacturer (GM/Getrag) has chosen to implement into the 2006 assembly for added strength, are the very same one's we've already engineered into our HD differential products for the last three years now.... Funny how that works and if the manufacturer chooses this, we know were already on the right track!
Best Regards,
DTE
Old 10-04-2005, 04:02 PM
aaaaa
aaaaa's Avatar
Thanks for the info.
Old 10-04-2005, 06:11 PM
markbrown
markbrown's Avatar
i have a very late 05 auto and was wondering what the part number would be and is it exposed so that you can find it?
Old 10-05-2005, 01:13 AM
LS1LT1
LS1LT1's Avatar
Oh and thanks again for providing the pics and info tekhombre/Cartek Racing.
Old 10-05-2005, 01:47 AM
ZZR1200
ZZR1200's Avatar
Same one? Which one ?
To C6 rear/differential 2005 to 2006 Changes.
Old 10-05-2005, 03:51 AM
shopdog
shopdog's Avatar
I'd say especially the automatics. There was some concern that with all the extra torque multiplication in the A6's first gear, the diff would be under a lot more stress. Seems GM thought that way too, and beefed up the diff to handle it.
Old 10-05-2005, 10:56 AM
LS1LT1
LS1LT1's Avatar
Originally Posted by ZZR1200
Same one? Which one?
Umm, he was asking which rear the Z51 package uses, my response was "the same one" as in the same one as shown above which should, to the best of my knowledge, also be the same one as the base (6 speed) car.
Good point, this would also make more sense from a manufacturing/parts supply point of view as well, less part numbers to make and stock, hope so.
Old 10-05-2005, 02:48 PM
Lazerwolfe
Lazerwolfe's Avatar
Location: I am Jack's out-dated Fight Club reference. MD
Quick Reply: C6 rear/differential 2005 to 2006 Changes.
