Easy Way To Identify LS1 vs. LS6?
Hi all,
I was wondering if there was a quick way to identify the LS1 & LS6 by just looking in the engine bay. Now don't go saying "Just look at the fuel rail covers!?!? Duh!". I've already thought about that. Any help would be appreciated.
Matt
Matt
yep. there is a 243 stamped on the heads. i forget what the # is for an ls1 but its not 243.
standing on the passenger side, you can see it toward the front of the head
the 243 is on the block too but not shure where
Thanks for the reply. I have aftermarket heads...so you think that 243 is on the block somewhere? Anyone know where that might be?
Thanks,
Matt
Thanks,
Matt
The engine ID number is on the block just behind the driver side head.
(not the easiest thing to see) If the eighth digit is an S its an LS6 if its a G its an LS1.
Location: I'm not quite middle aged and I only own one gold chain! San Jose CA
There is usually an LS6 sticker on the top of the throttle body. If you just have the block then it is identified in the numbered code stamped on the block.
Thanks for all the help, but a picture or a more detailed description of the location of the stamp would be appreciated. My engine compartment is fairly dirty and may be obscuring the number. I couldn't find it when I was looking earlier.
Thanks for any help.
Matt
Matt
Early LS1's have the bullseye stamped on the top edge of the block, above the timing cover. LS6 blocks do not. This was true until 02. My best friend just bought an 04 GTO and it does not have ther bullseyes, and I don't believe it came with the LS6 block. The intakes are easy to tell apart, in 01 when they started using them there were brass inserts on the passenger side for the throttle cable bracket to go on f-bodies. GM made them all this way to save $$$. 00 and earlier cars look the same as they dont have EGR like f-bodies do, but they also lack the brass inserts.
I have an aftermarket intake. Anybody else?
Matt
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I am going to have to start looking for numbers. I have an '02 which is supposed to have the LS-6 block and intake manifold but like the above I don't know how to check this. Great thread. I hope we get more info from the people in the know.
Originally Posted by Lancer033
wouldn't the block #s be the same on LS1s and LS6s since they started using the same blocks in mid 2001?
