66 Roadster Carpet Installation --Help
I am finishing a complete restoration on my 66 convertable and cannot find how to cut, glue and fit the carpet. The cut for the seat mounting is confusing. Is it a slit from one end of the seat bracket to the other or is there something else on the ends where the mounts are? Also, there must be some order to what pieces go in first in the back.
I called Al Knock for help and he said he would call me back in 5 minutes. It has been 24 hours and I have about given up!!
Any help will be appreciated. Any pictures would also be a big help.
I recently installed a conv. top and complete carpets from Al Knock. The video that I purchased to install the top was excellent. The only problem was it didn't talk much about rebuilding the bows.
During the installation of both I had a few questions for Al K. I would call and get someone who couldn't answer my questions and told me someone would call back. THEY NEVER DID! This happened at least 3 times.
There product is great, but there service is the worst I've dealt with within the automotive world.
The only thing I can say about the carpet is to take pictures of the removal of the old stuff.
Sorry to vent, but I think people should know about POOR SERVICE.
Hopefully someone with a 66 NCRS JG will chime in and tell you what's "correct" for your 66. Don't cut till you find out. Chuck
Carpets use a cutout flap which allows the seat runner to bolt directly to the floor panel with the carpet covering the runner and bolt from view. This flap is used at the forward seat anchor location only. The carpet is cut in a manner so that the hinge of the flap is toward the middle of the seat and hinges to close from inside to outside (i.e., the hinged portion is inboard of the seat rails). The flap should be approx. 2"x2".
Here is the order of installation which I use:
1. Panel behind seats. (place a 1"x4" board on the front side and a 1"x2" board on the backside and clamp in place . This will hold the top radius in place until adheshive dries).
2. Rear quarters. (the top portion usually needs to be trimmed to fit).
3. Storage compartment floor and rear wall. (you may need to trim a little carpet off the bottom at the differantial bumpout so the jack compartment cover will fit properly
4. Front foot wells.
5. Front kick panels & jack compartment cover.
Dave
Good advice on this. My Knoch carpet kit is in my garage and slated for this winter project. I'm going to get a polariod or digicam and photo each step, great idea.
Somebody out there has a carpet video, I think - one of the vendors, not sure who - Is it Corvette Central?
