[Z06] Tech Svc Bulletin!
Tech Svc Bulletin!
Anyone know of a TSB for relating to the tranny's of 02 Z06's for bent forks or the like? My shifter is jamming coming out of 4th.
Get Some!
Originally Posted by Michrider
Ask your dealer to look up PIP3020.
It tells to replace aluminum 3-4 shift fork with iron 3-4 shift fork.
Also replace 3-4 synchronizer and 3-4 blocking ring.
Here is a bulletin from GM
6sp M/T Stuck in Fourth Gear Will Not Shift Out of Fourth - kw bind block clash grind hard hop inoperative manual M12 MM6 MN6 no noise out performance second third transmission #PIP3020 - (Jun 18, 2004)
6sp M/T Stuck in Fourth Gear Will Not Shift out of Fourth
The following diagnosis might be helpful if the vehicle exhibits the described symptoms in the PI.
Condition/Concern:
The Chevrolet Corvette, Camaro and Pontiac Firebird equipped with the 6 speed manual transmission may exhibit the following conditions.
Primary condition: Unable to shift out of fourth gear. Other conditions may be:
3-4 upshift: hard shift, gear clash, or block-out.
4-3 downshift: hard shift, gear clash or block-out.
2-3 up shift: hard shift, gear clash or block-out.
Third gear hop-out.
Fourth gear hop-out.
Recommendation/Instructions:
Replace the aluminum 3-4 shift fork with an iron 3-4 shift fork. The aluminum shift fork is no longer available from GMSPO. The 3-4 synchronizer and 3-4 blocking ring should also be replaced at the same time.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
Models:
(97 - 03 Chevrolet Corvette ) and (97 - 02 Chevrolet Camaro) and (97-02 Pontiac Firebird)
Condition/Concern:
Third gear hop-out.
Models:
You may want to remove the boot and console plate and adjust the shifter. My car was getting hard to shift in 3rd and 4th, and I found the shifter to be a good ways out of adjustment.
Originally Posted by ososlow
How do you adjust shifter/linkage?
This is a fairly common problem actually.No amount of adjusting is going to fix a bent shift fork...My opinion anyway
Received 8,928 Likes
Anything noted about transmission downshifting problems? Most of the time when I approach turn 1 at Watkins I am slowing from about 130 in 4th to the high 60s under hard braking. With the clutch in I get gear clash or blocked from downshifting as I am trying to get the tranny into third. After a couple of tries it will go in. The next spot I try to downshift I am slowing from about 110 to 60 going into turn 6 under hard braking and the tranny will go into third everytime.
Bill
Bill
