[Z06] Crane 1.8 Gold Race Rockers
Installed a set of the Crane Gold Race 1.8's. The installation does take alittle time due to lifter bleed down and thread lock curing time. The rockers are very well made and provide an increased lift of .035". I do feel an increased seat of the pants feeling, but will verify the dyno result on the 28th of August over my baseline listed in my sig. I hoping for 10rwhp but who knows.
They were around $775.00 including overnight shipping. What you get is the rockers, 7.25" chromemoly push rods, push rod guide plates and all the studs and adjusting nuts. I purchased them through Corvette Garage in Texas.
http://www.corvettegarage.com/produc...-Corvette.html
When was your last dyno done? Was wondering if you are going to run into the same results that I did. My before install dyno was in Nov and my after was in July. I guess will see if any real gain this fall.
Here is the weather history in Nov 2004 when I had the first dyno. 58.7 °F and 83% humidity at 12 noon.
Here is the weather history for July, 2005 76.5 °F and 80% humidity at 2100hrs
As far as valvetrain noise, I didn't think mine was real bad to start with. Either its the same or a little quiter and I'm used to it already.
NCM, WSCC & SCC Member
With a correct tune you should get about 15 rwhp. About 20-22 rwhp on a 427. Due to higher lift, less friction, etc...
Much more importantly, you will get 10+hp/torque across the entire rpm band. This is really what makes you go fast.
Originally Posted by 02redzo6
Did these rockers add or remove any valvetrain noise.Thanks
