cold water dripping on my ankle...?
today we were out cruisin with the ac on and cold water dripped on my right ankle a couple of times...
is this some kind of condensation from the ac or what?
is it normal of do i have a problem?
thanx!
thanx!
Yeah take a look under there and find out where on the climate control box the water is leaking out of. Could be just the Evaporator drain hose had fallen off. You wouldn't believe the amount of water the A/C squeezes out of the air.....
Cruise-In VII Veteran
common prob w/ c5's, there's a drain behind the pass. side head on the firewall that clogs, cut the opening a little larger and that should keep it from clogging in the future
Received 1,673 Likes
Clean out the little udders on the firewall, you'll be shocked at how much crap you'll get out of them!
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Isn't that part of the Ol' Chinese Water Torture? Sorry ...couldn't resist.
With jrose
With jrose
Received 19,218 Likes
'20-'21-'22-'23-'24
It's not normal. Check the above items before it gets worse and you have water on your carpets and into electrical components.
clogged drain
My 2000 is doing the same thing (leaking water) on the passenger side. Where is the drain/hose located and what should I look for? I located the two utters on the drivers side under the hood behinf the wheel well. What is the purpose of the utters? Thanks.
