C6 Z51 Brake Squeal/groan Fix!
Old 07-28-2005, 05:21 PM
CorvettePartsBob
CorvettePartsBob's Avatar
Default C6 Z51 Brake Squeal/groan Fix!
This is a new bulletin just released for this problem. GM has plenty of the rear pads in stock, but very limited supply of the front pads inbound from the mfg. GM Parts was not aware of this bulletin and I passed it on to a supervisor and advised them they better get a bunch of fronts on hand asap. If you are having this problem notify your dealer and give them this bulletin # so they can order you new brakes. Remember this is not a recall, but just the information for a dealer to do a repair under factory warranty.
Bob
Document ID# 1682443
Brake Squeal on Vehicles Equipped with Z51 Package - keywords disc front groan noise pad rear squeak #PIC3320A - (Jul 8, 2005)
Brake Squeal On Vehicles Equipped With Z51 Package
2005 Chevrolet Corvette With (RPO Z51)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that when they apply the brakes, the vehicle exhibits a squeal noise. This squeal noise is heard coming from the front or rear of the vehicle. Vehicles produced with the Z51 sport package are equipped with larger rotors and harder pads.
Recommendation/Instructions:
Replace both the front and rear brake pads with the part numbers listed below. Both front and rear pads need to be replaced due to the difference in composition of the brake lining material. The existing rotors should be used and it is not necessary to machine the rotors.
Part Number
Description
89060211
Front Brake Pads
88964095
Rear Brake Pads
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Old 07-28-2005, 05:39 PM
ALFONSE
ALFONSE's Avatar
Mine don't squeal but GREAT INFORMATION, THANKS!
AL
Old 07-28-2005, 06:31 PM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Awesome info! Thanks!
Old 07-28-2005, 09:11 PM
pasquale
pasquale's Avatar
Thanks...........this is perfect!
Old 07-28-2005, 09:12 PM
MichaelB
MichaelB's Avatar
St. Jude Donor '06
Bob comes through again!!
Old 07-29-2005, 12:41 AM
barney
barney's Avatar
Thanks for the information. I got mine done a week and half a go. It sure is nice to stop at a light and not have everyone looking at you because your brakes are noisey. Your info should be helpful to a lot of people with Z51.
Old 07-29-2005, 12:50 AM
ASZ2222
ASZ2222's Avatar
Thanks!
Old 07-29-2005, 12:57 AM
S2K
S2K's Avatar
Why don't they have this for non-Z51's which also squeak?
Old 07-29-2005, 10:44 AM
Vette junkie
Vette junkie's Avatar
My Z51 just turned over 3,000 mi. and has not squeeked once ever. Serial #20796. Is it possible that a running change was made on the brake pads to the new parts and if so is there any info on which serial #s the change applies to?
Old 07-29-2005, 10:48 AM
Greystone
Greystone's Avatar
My Z51 breaks actually didn't start squealing till I got past 4,000 miles.....
Old 07-29-2005, 12:28 PM
FastMover
FastMover's Avatar
Location: Tellico Plains, Tn "Wolf" Official Corvette Guard Dog
Cruise-In II Veteran
Cruise-In III Veteran
My Z51 C6 was built in Jan 2005 and NEVER made a sound until last week at 7705 miles, now it always make noise.... But thanks to Bob's info my dealer has new pads on order
Old 07-29-2005, 07:49 PM
spydey95
spydey95's Avatar
Default Awesome
Great information. I had this squeal starting around 3500 miles, and now I have 8k miles (squeal still there). I guess it was a minor annoyance, but hey, if they're going to do a service bulletin under warranty....so I gave my dealer a call. They said they'll have the brake pads ordered. By the way, I also came in for the Service Fuel System light fix about two months ago. That was a two day job. Let's hope brake pads won't take that long.
Old 07-30-2005, 02:22 AM
2005ArcticWhite
2005ArcticWhite's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'18,'20-'21,'24
Good info
Old 07-31-2005, 01:07 PM
C6-Phil
C6-Phil's Avatar
My 2005 Z51 has just over 1000 miles and the brake pads seem to be dragging. This only happens when I first start to back in to the garage. Anyone experience this?
Old 07-31-2005, 01:15 PM
SunsetC6
SunsetC6's Avatar
Yea, mine does it as you release the pedal. Wondering if the new pads help. I'm new here this week but have had car since Feb. Found out a lot of really helpful info. Lot of nice people here. Think I'm gonna stay awhile.
Old 07-31-2005, 01:30 PM
mnmvette
mnmvette's Avatar
Have you noticed any difference in brake dust?
Old 07-31-2005, 01:36 PM
C6-Phil
C6-Phil's Avatar
Yea, I like this site too. I have had my Vet for a month now, and the noise is not to bad. I think I will wait on the new pads until they start to squeak, looks like that happens to all Z51 owners eventually.
To C6 Z51 Brake Squeal/groan Fix!
Old 07-31-2005, 01:46 PM
natejohn
natejohn's Avatar
Default what about......?
I wonder (though fear ino the answer) if this "fix" is appilicable to cars that didn't come with the Z51 option but have sinced switched to Z51 brakes?
Old 08-02-2005, 03:33 PM
NavyC5
NavyC5's Avatar
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
Awesome. Mine are making noise. I wonder if the dealer will order me the new pads but let me put them on. I don't trust my dealer at all.
Old 08-02-2005, 04:39 PM
LKicklight
LKicklight's Avatar
Default Brake Groan or Squeal on Z51's
Okay Boys and Girls, here is the scoop..yes this bulletin does address the squeal problem we so often hear, but even though you replace the exsiting pads with the replacements recommended, beware, when they wet or high humidity, more than likely they will squeal and groan again. Also, braking performance is also comprimised, how much?????? These particular replacement pads or not true ceramics, which if they were 100% ceramic, there go your pads and rotors. Your brake dust will be less also using these replacement pads. No more than I drive my C6, I can live with a little less brake dust, less squealing and a little less performance, all three of these were really bugging me. Dirve the car ten miles and the darn wheels have to be washed off, go over 50 mph and you sound like a tanker truck pulling into a parking lot.
KICKBACK
Quick Reply: C6 Z51 Brake Squeal/groan Fix!
