[Z06] cabin partition
cabin partition
I'm looking for a cabin partition to be installed right behind the seats so that I can't see all the way down to the trunk.
I tried searching but didn't find anything that could help me
Thanks for you help!
I have the $99 2.5 inch thick foam (oem carpet and Z06 emblem) from Ecklers. It's a compression fit so no drilling is required like others. I really works well to quell the exhaust and road noise. The cabin cools faster and the stereo sounds better.
You can spend as much as 4 times more for a partition. Andy's comes to mind as one of the more expensive but good looking partitions. It all depends on how much you want to spend and the look your after.
Take a look at the Eckler's:
Here's the reason the Z is so noisy, there is no insulation under the carpet:
Some DynaMat kills most of the noise:
Good luck
Tom
Good luck
Tom
We have alot to choose from!
Before you decide to pay $100 for hunk of foam,Please check out our product line.
We have the best deal on the net going right now here -
http://www.z06vette.com/forums/showthread.php?t=83864
If you want to spend less - We start our pricing at $159.00.(Free shipping on our full carpet partition with quick release mounting hardware)
Guaranteed not to ever do this like some others that are out there-
Andy
Andy
I forgot 1 thing!
In stock and absolutely no hagggggle return policy,Try that with some of the big names.I am trying to be as informative as possible since your really are new here and you deserve this info along with all members here.
Here is a pic of the carpet you will recieve if you buy from most others:
Here is what you get from us:We use OEM materials only!We do not offer general black any longer,you will recieve what is pictured here:
Former Vendor
How will this partition affect a system? I have a 12" in a box in the trunk but I dont want to buy it and have it muffle the bass. Right now it sounds loud and clear.
Originally Posted by ZO6PARTS
Before you decide to pay $100 for hunk of foam...
Hmm... foam. Let me ponder that. Performance car, in which they cut every corner to save weight. Foam, hmm... seems pretty light. MDF...not so light. Not sure what is in yours - I have seen a lot of partitions say they are made from MDF.
Maybe you make a better product, I have no idea, but I'm thinking I wouldn't go blasting foam if I were you without specifically pointing out the ultra light weight space age materials used in my product that make it worth so much more money.
I have a 20 lb dog I sometimes take along and I was afraid the Eckler's would not hold her if she lost balance when I accelerated. But the fiber board added much too much excess weight.
BTW, if you sew along the exterior of the partition your stitches will be hidden by both the fabric and the placement of it in the trunk space. The sewing turned out to be an easy part of it and the fabric store people will provide instructions once they see what you are trying to do. I took my cut out sound board into the store and we used it to purchase the right amount of material.
Good luck, whatever you decide.
ArmchairArchitect (05-07-2017)
I tried to look at Ecklers, but couldn't find the exact product. What is the name or number of it?
Thanks!
"who makes that carpet and where can i get some. im makin an amp rack where people have thier vette trays and want a perfect match."
As the C-5 Z06 cam to an end so did the manufacturing of all the materials,contract with gm and supplier no longer exists.
We bought a 3 year supply(1500 yds or 2.5 partitions per yard) when word came down the pipe that it would no longer be available.We are the only location for OEM Z06 CARPET.
We sell it to the public for $45 a yd(36"x60.5")
Hope this helps
Andy
Hope this helps
Andy
"How will this partition affect a system? I have a 12" in a box in the trunk but I dont want to buy it and have it muffle the bass. Right now it sounds loud and clear."
I spent many years in car audio and found more subs in trunks of cars play through just fine.Sub-bass is undirectional,so it will travel as we all know.Expect a little more gain to be added to the amp that is on the subs,but no biggy.You will also get less cone distortion since the woofer is behind the wall simular to a bandpass box which filters all cone distortion.
Andy
Andy
"Instead of heavy fiber board you can use light weight sound board"
We can sell you a partition that weights in at a whole 7lbs....Hmmm.
or
I can sell you the material (board cnc cut already)and you can cover it your self like Charles Mitchell would like everybody to do,for $20.00 plus shipping.But you will need to take half a day off and go find some materials to cover it in,But that is no biggy.
or
or
or
