Electronic Cut-outs - Who's got 'em?
I have Corsa Pace Car exhaust. No other mods. Thinking electronic cut-outs could be a lot of fun when I want to make some noise. Have no plans to bring car to track. Did some research but couldn't find answers to following. Any help/tips would be appreciated.
1)Is there a vendor that sells both the cut-out component(the small y shapes exhaust peice) and the electronic control mechanism?
2)Will the engine get all confused? Is there more airflow when the cut-out is open?
3) I would put the cut-out behind the CATs to ensure I pass inspection. Anyone have problems with inspection?
As Always, THANKS
As Always, THANKS
Wil Cooksey #256
As Always, THANKS
As Always, THANKS
You can see in the pic the turndowns that I put on behind the cut outs and roughly the way they are oriented under the car behind the fiberglass "tub" between the exhaust pipes.
Sorry for being so long winded, just thought I would help you out a little since others did so for me when I was looking for info here before installing mine.
This obviously is not the only way to do this install, but this is how I did it and am very happy with my results. It is a great mod in my opinion.
well...i have a set of QTP cutouts... and they have been nothing but problems... prolly due to the fact that my car is lowered and i rub/bang the cutouts all the time. i have an A4, so they sit directly under the tranny pan... a very dangerous place i know, but i didn't do the work, bought the car with them on...
so, the cutout is AWESOME for shows or cruis-ins and what not. sounds mean as heck on the road as well! u can literally feel the beat in your body... keep in mind, my car is a 427, no cats, straight 3" piping. so its LOUD!
a few things with QTP's cutouts... they can't seem to built them correctly. i have had to send in one cutout already b/c the adhesives they use to put the motor on the flange is just weak. looks literally like it was shrink wrapped on. it doesn't hold. it doesn't matter how many bumps and things i hit, its a matter of quality on construction. actually, one of mine broke this weekend. so gotta send that back in for repairs. it costs $30 to repair. about a 2 week turn around...
overall though, i love my cutouts!!! but its sometimes not worth the hassle...
my dyno vid link below in my sig has ONE cutout open, so u'll kinda hear how she sounds... enjoy!
Aj
Aj
Aj
Aj
How do you feel that we dont know how to build them correctly? You already stated that you rub and bang them on the car. How do you expect any part to last long if it is abused like that. We build a top notch unit and have over 10,000 units out in the market place. When installed correctly there are no issues. So please correct your install issue before pointing the finger at the manufacturer.
Originally Posted by Quick Time
AJ
and with the rubbing, i know, its my fault, i have no problems with that, and really, i don't think its the rubbing that is causing the tape to fall off...the motor/flap assembly is all one peice...bumping/rubbing will cause the whole thing to move, not individual pieces.
i didn't mean to insult you guys or your products. i love them very much and if i could, i would put them on all my vehicles...
please accept my apologies...
Aj
P.S: did u watch the vid..did u hear that! lord knows how many times i have been complimented on the sound of the car..all thanks to QTP!
Aj
AJ
Rubbing and bumping will cause the internals of the motor to go bad. That is why we stress the location and clearance of the units. The rubber is just a cosmetic peice. Sounds like you have it a little to close the pipe. Either way we can help you out on the repair.
For a C5 you would only buy the vales for $304.99 and have a muffler shop make the cutouts on the pipe. Stick cars have a different location than automatics.
And you want we have a complete system. Cutouts already mounted for 6 spd cars.
IMO our system will give the most power across the board and put down the ETs! Not just on the dyno.
If anyone has questions feel free to call us.
I have mine in the same spot as Rajin Cajun. I love 'em. FWIW- I took out my cig. lighter and put the switch in it's place.
Here is a pic of the switch in my console, I have not taken any more pics since I moved it.
QTP do you offer installs?
Sounds like if the install is done 100% right (I have an a-4), then you have a great product, that works quite well.
What would the cost be INSTALLED be on an auto with GHL's.
Barry
where would u suggest placing the cutout on a A4 car? mine is currently under the tranny pan. a very dangerous spot i may add, but i didn't do this install. bought the car that way. i would love to re-located it no matter how much it cost. the bumping/rubbing not only keeps killing my cutouts, they put a slight dent in the tranny pan as well...the slight dent may turn into a hole if i hit the thing hard enough!!!
thanks again Barry...and my apologies....
Aj
Aj
Mine are exactly like this:
http://www.mccordcg.com/mpp/edbon.htm
I installed the switch in my gauge pod
2) Not too many places to install these on the bottom of the C5. Most ppl install them close to the back of the car which is waaaay behind all of the cats and O2 sensors. No interference there. I did this mod for the ability to make my car hell-of-a loud and then back to stock quietness at the push of a button. I think the C5 exhaust setup is pretty free flowing already so not sure the HP gain if any from cutouts.
3) We have no inspections here in Iowa. Don't know how picky other states are...
Originally Posted by Ragin'Cajun
I have some QTP cut outs......It is a great mod in my opinion.
Do you have any other pics more directly under the car? I would like to get abetter view of where you have them.
Thanks,
Rob
