[Z06] Fog lights
Fog Lights
Check this thread.
http://forums.corvetteforum.com/show...18&forum_id=53
They have never been an option on the Z (weight savings) same is true for 12 disk changer, passenger power seat, trunk covers, power antenna, telescoping steering column.
Lots of us install some of these items.
Jeff
Jeff
Originally Posted by Shylor
No fog lights and why would you ever want them on a muscle car?
Just bought the car wanted to see if I was getting everything i was supposed to...origionally when i saw the car and had the head lights on I could have sworn they were there but i guess it was just the day time running lights lighting the grills up.
I installed the PIAA driving lights with an OEM switch. Total cost less than $180. I find I seldom use my headlights at night with the PIAA's unless I'm at freeway speeds.
The PIAA's are far better than the OEM fog lights. Your better off not having them in the first place and installing the PIAA's.
Tom
Tom
Originally Posted by diverdan
PIAAs are an easy upgrade, especially if you use a coupe/vert on/off switch. I've had them for a year and have been very happy.
Originally Posted by TheDVS1
How well do the PIAAs work behind the Z's intake screens?
Make sure they get adjusted correctly, particularly if you run them as low beams sometimes. They put out great light, but are real annoying to oncoming drivers if set too high.
Tom
Tom
Originally Posted by Silver98
Anyone have the install procedure for fog lights?
What's the $180 parts list?
I am thinking of putting them on my Vette since it didn't come with them.
TIA,
Joe
TIA,
Joe
.........Any questions?
Also, the PIAA lights greatly enhance night visibility vs. the crappy headlights. And to call the Z06 a "muscle car" doesn't do it justice-- it does far more than go in a straight line.
Originally Posted by Thud
Any questions?
Originally Posted by t56gen3
Tuan Lee can fix you up with all that. http://forums.corvetteforum.com/show...8&page=1&pp=20
Tom
I think my original question still stands. Fog lights do nothing more than annoy oncoming traffic. If you want increased lighting then just get better headlights.
Tom
TIA,
Joe
TIA,
Joe
I highly recommend you get the fog light/trunk release switch panel from a coupe/vert; there are instructions on this forum on how to wire the PIAAs into the wiring that the stock fog lights uses (even though the Z doesn't have the lights, it has the wiring) changing out your trunk release only switch for the fog/trunk switch takes all of 15 seconds. You can get the switch panel from forum sponsors Fitchner Chevy, or Fred Bean Pontiac for about $35 last time I checked.
Overall, the install is easy and the forum instructions have pictures.
