Hooking AVIC 1 up to the PCM.
I have had an AVIC for almost a year, and the vehicle dynamics wire has NOT been hooked up to the PCM. The wire(pink) is hooked to the AVIC, and all ready to go into the PCM, but, I have no idea where or how to hook up. My car is getting worked upon so i have the ability at the moment to have it on a lift. I guess there are "pin #'s" on a PCM, and the pink wire goes into a "pin #"? Can someone please give me some help in hooking this up.
Thanx
Jim
Thanx
Jim
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Hope this helps...
Is the pink the speed sensor wire ?? if so here you go.
After some, disassemble of the dash of course with the service Manual in hand! I found the right green/white wire. It goes to the plug on the back of the instrument cluster. Actually there are two green/whites, one is for the Oil Temp the other is the speed sensor wire.
After unplugging the connector from the cluster you will find two green/white stripe wires, you will want the Green/white (A7-circuit 817) with a Tan/white (A6-circuit 33) above it and a black (A8-circuit 150 ) below it..The other green/white (A10-circuit 357) oil temp has a blank and a gray on each side.
pin..wire
A5 Blank….
A6…Tan/White
A7 Speed Sensor…Green/White
A8…Black
A9 Blank
A10 Oil Temp…Green/White
A11…Gray
http://www.vetteessentials.com/inst...ezel_howto.html
Step 9c shows the plug...I did not have to remove the cluster to reach it just pull it forward..
pin..wire
A5 Blank….
A6…Tan/White
A8…Black
A9 Blank
A11…Gray
Location: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
Originally Posted by boatboatboat
thank you.
Could I also tap into this Green wire with white stripe at the PCM, rather then taking the dash apart?
i also have avic-n1 btw but i'm not running with the speed sensor wire hooked up.
St. Jude Donor '16
thank you.
I was wondeing about this.
does the stock head unit work off a speed sensor wire as well? It has that volume thing that turns up the stereo louder as you go faster. if yes, then would the green wire with the white stripe on the back of the stock stereo harness be the speed sensor wire?
Wish I would of seen the post about the wire being in the cluster while I was installing my HUD. would of nailed it right then.
St. Jude Donor '16
Bill hope you get things worked out...I tried the green/white on the raido plug also..it is a speaker wire.
Steve
Steve
