[Z06] Flat tire repair.
Flat tire repair.
How well does the tire sealant/electric inflator work for the Z? I'm thinking of taking a long trip in my 01. Is there a company that makes a "donut" spare...just in case?? I'll make sure my AAA membership is current.... Thanks!
If its a 01 check the expiration date on your sealant....I just got a flat. I went to use the sealant and it was expired. It was too THICK to get into the tire. I just used the tire inflator and drove slowly to the nearest shop.
Tire repair
I don't know of any donuts that could be used both in front or back
I know you are not supposed to do this but I used the regular fix a flat once and it got me safely 5 miles to a repair station.
Spare tire in a can or Slime is just as good as the GM sealant. The tire inflator pump is no different than any small electric air pump. A vulcanzing tire plug kit is much better used with a small jack, in case you have to take the tire off the car to get to the hole.
Location: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
Tire plugs are real nifty if it's a small enough hole, & in the tread area. I have never had a problem with any plug I have personally installed(about 1/2 a dozen to date?). Keeping some Slime stuff on hand just in case a plug can't be used is a good backup, & if between those two fixes you are still flat, call for help.
BTW, the inflator works pretty well, but be sure your engine is running, otherwise the inflator is turning too slow, & it will take forever. Don't ask how I know this .
The GTO spare idea came up a while back in another thread. I asked and no one ever came forward stating they had actually driven a vette with a GTO spare on it. The bolt pattern is close enough but if you look in that picture the car is still off the ground. The GTO spare is 17", I believe, so would be mismatched to the other tire on the back. I have been told that such a mismatch would damage the Limited Slip Differential if you drove any distance.
I bought my GTO spare for $75. The wheels lists for over $400+. It is aluminum. It fits front and rear and is a 17". Frderick, that sells the mercedes jack suggested a Jag spare with a spacer. No spacer here with the GTO. If it supports a GTO wouldn't it support a vette.
I would certainly be willing to get a GTO spare and put it in the car any time I took a long trip; I hate the thought of relying on the goop to fix a flat. I just would hate the cost of a rear end rebuild even more.
When I get a chance, I am going to pull out my GTO's spare and and measure it's total circumference as well as that of the front and rear Z06 tires, unless someone already has that info available.
Let's say your flat is one the rears, could the 2 fronts be put on the rears? Then put the gto spare on the front. One argument is what to do with the flat tire? What if some guber pulls up behind you and decides to rob you and rape the little lady? What if the traction control is shut off? We need a engineer to answer?
Get Some!
I keep this kit from JC Whitney, it will fit inside a shaving kit bag. Take some rubber gloves out of your first aid kit to use with this one.
http://www.jcwhitney.com/autoparts/P...Group?Ntt=tire
Does anyone has a sealer for this I had a blow out
http://img.photobucket.com/albums/v6...s/IMG_1114.jpg
Get Some!
