Changing driver side turn signal bulb
I removed the shroud from around the headlamp. I pull on the grey plastic but it wont budge. Is there a locking mechanism or a certain way to remove it? I dont want to break it and have to vist the dealer again for my semi monthly donation
The easiest way to change the bulb is to get to it from underneath. If you jack it up and put it on stands you can see where part of the black shroud will unscrew. I think there are about 7-8 screws holding it in place. Once you take these out and remove the piece you can reach right up and remove/replace the bulb. Installation is the reverse. You can pick the bulbs at Walmart pretty cheap too. Good luck on your project.
twist and pull....
Changing the bulb is pretty easy, even easier if you have small hands.
Raise the hood. Look for the large black **** next to the headlight. It has a rubber cap on it that says, "Remove for manual operation". Remove the cap and crank up the headlight. Yes, you can raise the headlight electrically, but you risk draining your battery while you're replacing the bulb.
Remove the black plastic cowling around the headlight. There are three small screws - avoid dropping them into the engine compartment -. You (or person with smaller hands) now have room to reach down to where the turn signal bulb is located. It's a bayonet type mount meaning a 1/2 turn should disengage it. Then remove the old bulb and install the new one. CAUTION - do not touch the glass on the new bulb. Doing so will ruin it due to the acid in/on your fingers. Reinstall the fixture in it's mounting hole.
Turn on the ignition and check to see that the turn signal is operating properly - DO NOT turn on the headlights! Next, replace the headlight cowling, and manually lower the headlight. Replace the rubber cap on the ****, and you're done!
The part number for the bulb can be found in the back of your owners manual.
Originally Posted by corvettejaune
I have change my bulb anad the number ove the bulb is #3157
regard
regard
Originally Posted by C5-BRUCE
If I recall, the part number listed in the owners manual, likey the one listed in the quote above, is the same bulb for the running lights as it is for the turn signals. The running light is amber, and (I think) is designated with either an "A" or "AM" as a suffex to the part number?
My owners manual lists 3057 as the bulb model. That was wrong. The bulb that was installed was an amber 3157. Went up to Kmart, bought a pack and replaced both sides as long as I was doing it. I was just able to jam my wrist through the brake duct using surgeons gloves with some powder. It hurt, but I got it done. It took about a minute for each side.
Ed
Turn signal for 2000 C5
Ok I finally changed the halogen lamp. Is that the turn signal? Well it didnt work. All the other lights work but the left front turn signal wont work. Is there a fuse for just the turn signals. Its kinda hard as the owners manual is in Florida and I'm in California. Any ideas
