Axle seal leak @1200 miles...anyone else?
Old 07-06-2005, 05:04 PM
UNKNOWN
Support Corvetteforum!
UNKNOWN's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Axle seal leak @1200 miles...anyone else?
Car in shop for new seal...anyone else have this issue?
Results?
ty
blznsdl
Old 07-06-2005, 07:42 PM
bangbgC6
bangbgC6's Avatar
I recall one or two others with that particular problem. I was able to locate this previous post that might fit.
http://forums.corvetteforum.com/show...al&forum_id=74
It's all under warrenty isn't it?
Old 07-06-2005, 07:48 PM
bangbgC6
bangbgC6's Avatar
Default Here's Another
There seems to be more than a couple. Here's another post
http://forums.corvetteforum.com/show...L&forum_id=101
May be a sub-club of owners, just like the Crank Pulley.
Old 07-06-2005, 08:33 PM
haljensen
haljensen's Avatar
Both examples given above (one of them my car) were NOT AXLE SEALS. Mine was a differential cover seal. Nothing to do with the axles.
Old 07-06-2005, 08:51 PM
LeedDog
LeedDog's Avatar
Default I did.
I had to have a rear axle seal replaced, under warranty.
Old 07-06-2005, 10:06 PM
UNKNOWN
UNKNOWN's Avatar
yep to warrantee...
UNKNOWN
UNKNOWN's Avatar
how long?
ty
Old 07-06-2005, 11:37 PM
bangbgC6
bangbgC6's Avatar
Sorry, I was just trying to be supportive searched previous posts and read about your drips, my mistake.
Old 07-07-2005, 06:40 PM
redhot6
redhot6's Avatar
I have the leak in the middle, around the diff. Needs to go back to the shop. The first time the dealer just put in a dye and told me to come back if it keeps leaking. Still leaks and will be taking it back next week. Seems like it always takes at least two trips to fix something.
Old 07-07-2005, 07:15 PM
Lee6
Lee6's Avatar
last week, under warranty, my local dealer replace what he called the "tansaxle seal"......
he said that this was apparantely a common problem....
(funny thing was.....it took them less time to replace the seal than
it took them to replace my front left blinker blub......lol)
Old 07-08-2005, 09:32 AM
UNKNOWN
UNKNOWN's Avatar
yeah mine too..
I think they may be draining a factory overfill and billing gm for the
seal replacement warrantee...not my problem tho..it's fixed just fine.
Old 07-08-2005, 10:02 AM
haljensen
haljensen's Avatar
No apology needed or wanted. This forum is full of people that use the wrong terms and use incorrect designations. This original post is a good example. Axle seals? Does it mean the boots on the CV joints? The seal from the diff. to the output shaft? The seal between the transmission and the diff? The seal for the side plates? The seal for the diff rear cover gasket? The seal for the drain plug on the diff? I just have to read between the lines and interpret the posts.
Old 07-08-2005, 10:26 AM
UNKNOWN
UNKNOWN's Avatar
Thanks forum for the feed back re: leak.
This forum also allows it's fair share of cynics with shallow egos and are know it allls.
Most of us use direct quotes and are often given poor or incorrect information and unknowingly pass it on. It's a forum!
I can give you the name of the service tech and you can ask him why you know more than he does. "It's an axle seal leak " quoted the tech.
I am just the mailman.
Old 08-03-2005, 04:06 PM
kloutfy
5th Gear
kloutfy's Avatar
Default Rear Axle Seal and Transmission to Differential Leak (Z51)
My vehicle exhibited leaks on the rear axle seal and transmission to differential seals at 700 miles. The following parts were replaced by the dealership:
12369456
89059670
89059457
12455044
12455045
88996703
The car was in the shop for a total of 6 days for this repair. The first visit was for 3 days at which point they told me to pick-up the vehicle because they did not have all the parts in stock. The second visit they replaced the parts and steam cleaned the underside of the car to clean away the fluid leaks. Total miles put on the car during the first visit was 10. Total miles put on the car during the second visit was 36 (6 of which were documented as a road test). They chalk up the additional miles to running the vehicle on the lift to check for leaks. This was from the same dealership that would not let me test drive a new vehicle.
The car was built at the end of June 2005. Other issues:
1. Brake squeal
2. Missing cargo net and luggage net from the factory (still waiting for these parts)
3. Interior rattle (inside dash near glove box?).
4. AC compressor would not turn on, happened twice.
I am very pleased with the performance of the vehicle but wish I would not have these issues straight from the factory.
Old 08-03-2005, 05:36 PM
kenrobb
kenrobb's Avatar
#3: Read the other day where someone had this rattle and they found a rivet either loose or missing at glove box. think they even said the plant knows about it now. Might do a search to find the article posting. Might be a fix to your rattle.
Old 08-03-2005, 08:27 PM
redhot6
redhot6's Avatar
I had my seal between transmission and differential replaced. Dealer advised that GM redesigned the seals and that there was a TB out on it. Seems there have been a few leaking.
Old 08-03-2005, 11:26 PM
rmitchell242
rmitchell242's Avatar
mine leaks on the drivers side cover and my dads is in the shop right now getting his fixed his leaks at the trans and on the drivers side
it sure is nice after about 3 miles on the freeway there is oil on the entire back of the car good job gm
im gonna let mine dry out and blow up
To Axle seal leak @1200 miles...anyone else?
Old 08-21-2005, 09:08 AM
gtfxhunter
gtfxhunter's Avatar
I just got mine back..I had the car only six days...found the trans..axle seal leaking...I believe it wasn't inspected at the delivery dealer as my car had just 300 miles upon discovery..wouldn't have discovered the leak until much later if I hadn't been interested in modifying the exhaust system...my advice is ..if you can..put your new car up on a rack and inspect it yourself ...can save time and money later on...
Old 08-21-2005, 12:53 PM
m3corvette
m3corvette's Avatar
Been there! Done that!! But it was a quick fix by the dealer.
Old 09-13-2010, 05:31 PM
LamboOnBass
Cruising
LamboOnBass's Avatar
Uh oh. how much does that cost. Recent (3 days a go) oil change discovered rear axle seal leak. My vette is an 05 c6 with 98,000 miles
Quick Reply: Axle seal leak @1200 miles...anyone else?
