[Z06] 03Z06+110hpNOS=11.48@124.27
Here's the breakdown...
60 1.897
330 4.971
1/8 7.490
MPH 99.74
1000 9.667
1/4 11.486
MPH 124.27
Mods are NOS dry jetted about 110hp, Vararam and Nitto R2's. It was about 78 degrees, 29.9 barometer, and 50% humidity. How to get DA I have no idea.
I realize I don't 60 ft that good but this was my first 11 second pass. What a feeling! Kinda spooked me at the end of the run my clutch pedal was stuck about 2/3 down for 10 seconds then returned. ??? I think I will take it easy on her for a while.
60 1.897
330 4.971
1/8 7.490
MPH 99.74
1000 9.667
1/4 11.486
MPH 124.27
124.27 trap speed and a 1.897 is pretty damm good. I wonder what your times would have been sans NOS. I'd bet high 11's.
I'd be proud to have the 60 time.
Tom
Tom
60 1.897
330 4.971
1/8 7.490
MPH 99.74
1000 9.667
1/4 11.486
MPH 124.27
60 1.897
330 4.971
1/8 7.490
MPH 99.74
1000 9.667
1/4 11.486
MPH 124.27
Where in the run did you spray the Nos?
You mph of 124 could yield a VERY low 11, 11.0-11.1x I think.
Nice pass!
Ron
Collections Hold
Yes. Low 11's are at hand. Congrats Chris, that was a bad azz run. With a little bit better tire and your shifting skills, the sky is the limit. Well now you have to get a roll bar as the cut off is 11.50. Remember, your 110 is rated at the crank, so to compare to other brands you have take 15% drivetrain lose in to account and that puts your hit at 93.5rwhp. They closed the track at ten, and I only got 3 runs in. The one run that I got 96.30 in the 1/8 would have beat my previous best (95.33), but as you know I missed 4th gear. I tried to use the dual stage but my clutch would not hold as it just slipped past 1/8 and had to let off. I can get a deal on a Textralia clutch (ls1tech moderator) and maybe I'll ask for two if ya want one.
Robert
Robert
Thanks for the feedback everyone. I don't have any tuning, and still use the original spark plugs. I checked for codes after the run and nothing. I'm watching for the lean code...
I sprayed outta the hole after I let the clutch out and went WOT. I leave at 3500rpm but have a bad habit of soft launch. Thanks for the info on DA, how do you get it?
I'm sure there's more ET. Only problem is the roll bar requirement and I wonder if the clutch can handle it. It was the first time my clutch pedal stuck, what's up with that? That's a real bummer your clutch is going Robert. I think I will just back off and save parts, otherwise it's gonna start getting expensive! I would like to hear how it works out for you.
St. Jude Donor '05-'06
Nice run! Sorry to hear about the clutch I have had that happen a few times to me, so I got in on the Ozzie GP with A n A. New clutch and DRs and you will be 11.0
Dave
Dave
I got the Da from http://wahiduddin.net/calc/calc_da_rh.htm.
The clutch sticking is common when you run the 1/4 w/ a mod or 2 on the stock clutch. You can just stick your toe under it & pull it up.
Ron
Ron
