Here is why your hatch button quits (pics)
Old 06-22-2005, 06:30 PM
Pipedreams
Pipedreams's Avatar
St. Jude Donor '06-'07
Default Here is why your hatch button quits (pics)
One day last week the hatch button (the one located on the car just above the plate) quit working after a wash. I found the button was stuck pressed in. The FOB and dash switch still worked fine. After a few days it started working again. From the many threads it appears to be a big problem. Since it's a 5 min job I ordered a replacement from Gene for $15 as compared making 2 trips to the dealer to replace (1st for them to see / order it and the 2nd to replace it) that’s allot of my time and chances for damage.
Listed below is why the switch most likely fails and how you can fix the one you have if you want to save 2 trips to the dealer and are handy.
The switch is located just above the rear license plate and is accessed by removing the passenger side tail light closer to the emblem. The tail light simply removes with one screw (T15 torx head).
Test
(If you want to test (have your FOB with you) to see if this will fix your non working button. Reach in and remove the harness (pull back retainer towards the rear and lift out harness) from the switch and press it back in. If the hatch opens when you reconnect the harness the switch is stuck in and the procedure below should correct it, if it does not open the hatch you have other issues. The button is a momentary contact switch)
With the harness removed, press the two clips in the picture and the switch drops down.
Remove the rubber cap from the switch by just pealing it back with your fingers. I found dust and sand in mine.
Attach a strong tape (electrical, duct or masking tape) to the button head only and pull out the button. Looking up inside you will see a rubber button that contains the contacts. There is no need to remove this since it’s the button that was stuck on mine most likely due to dust / dirt and water. Clean it well using a small paint brush and reassemble. I would not use any oils or grease since this will attract more dirt. Since the switch has no return spring it relies on the rubber inside button returning the removable button and any dirt offers enough resistance to make the button stick.
I ordered a replacement but could have just cleaned it and would have been fine.
Pipedreams is offline
Old 06-22-2005, 06:35 PM
Sparky65
Sparky65's Avatar
Great info. Maybe there should be a subsection under Tech Info for common problems and their fixes . . . .
Sparky65 is offline
Old 06-22-2005, 06:50 PM
dekaran
dekaran's Avatar
PipeDreams, I must hand it to you. You are way more tech savy than me... your pictures and diagrams are always so well put together. Thanks for the info.
dekaran is offline
Old 06-22-2005, 06:56 PM
need-for-speed
need-for-speed's Avatar
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Excellent write up
just curious, does this mean it will be a continuing problem ?
need-for-speed is offline
Old 06-22-2005, 07:01 PM
Pipedreams
Pipedreams's Avatar
Originally Posted by need-for-speed
Excellent write up
I am not sure if the replacement is any better, some at the birthday bash said they were treated to an improved (sealed) switch. I would think a TSB will follow.
Old 06-22-2005, 07:04 PM
chadwick
chadwick's Avatar
Great info, Thanks!!
chadwick is offline
Old 06-22-2005, 07:14 PM
V Vette
V Vette's Avatar
Thanks for report
V Vette is offline
Old 06-22-2005, 07:18 PM
flyzlow
flyzlow's Avatar
PipeDreams, I don't have a C6 yet but I'm glad that you are part of this forum for when I do! I am sure your expertise is appreciated by many. Thanks for being there. FLYZLOW
flyzlow is offline
Old 06-22-2005, 07:19 PM
TRAIL BOSS
TRAIL BOSS's Avatar
Thanks for the info!
TRAIL BOSS is offline
Old 06-22-2005, 07:25 PM
b4i4getit
b4i4getit's Avatar
Made in Canada ? I wonder if the button is English and French.
b4i4getit is offline
Old 06-22-2005, 07:37 PM
calemasters
calemasters's Avatar
Very nice post. This procedure will address the systemic cause of the failure, which is internal water intrusion and contamination. So that one does not have to repeat this procedure every few months, the root cause has to be identified. I suppose a "sealed" switch would correct the root cause of the failure. If the new part is the same as the original part, perhaps one could seal the switch with a silicon adhesive to prevent the internal water intrusion and contamination.
The old P.N. was 89023924, so maybe P.N. 10349807 is new and improved???
calemasters is offline
Old 06-22-2005, 08:01 PM
C7 BOB
C7 BOB's Avatar
The old one was a regular button with a gap around it where dirt could get in. The new one has a thin rubber cover that protects the gap.
C7 BOB is offline
Old 06-22-2005, 08:09 PM
Medriver99
Medriver99's Avatar
St. Jude Donor '07-'09
Thanks alot, I just fixed mine using your info.
You are the man. Gotta love this forum.
Thanks
Mike
Medriver99 is offline
Old 06-22-2005, 08:28 PM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
And to think PIPEDREAMS was gone for awhile. Thanks for the info bud!
Datawiz is offline
Old 06-22-2005, 08:38 PM
racinghotroddave
racinghotroddave's Avatar
St. Jude Donor '05
thanks for the info
racinghotroddave is offline
Old 06-22-2005, 08:48 PM
redhot6
redhot6's Avatar
Great info, Thanks....
redhot6 is offline
Old 06-23-2005, 12:47 AM
calemasters
That is a good thing. You always want to shoot for a corrective and irreversable fix.
To Here is why your hatch button quits (pics)
Old 06-23-2005, 05:14 AM
Miaugi
Miaugi's Avatar
Thanks - I'll save your post for future reference, cause you know I'll need it one day!
Miaugi is offline
Old 06-23-2005, 05:39 AM
juiceman03070
juiceman03070's Avatar
St. Jude Donor '08
thanks
juiceman03070 is offline
Old 06-23-2005, 06:02 AM
HOFFIE
HOFFIE's Avatar
Great writeup.Thanks for the info Ed
HOFFIE is offline
Quick Reply: Here is why your hatch button quits (pics)
