What fuel for 73 SB
Cruising
What fuel for 73 SB
Pardon my ignorance, but I've just bought a 1973 SB & was wondering what fuel should be used (unleaded or leaded) & what octane rating?
Russell
Russell
Cruising
Thanks for your help guys. I get my car next week (arrived in Brisbane from Florida yesterday) & wanted to make sure before I put the right fuel in.
Wow, guys. There were two smallblocks in '73 and the answer depends on which smallblock he has (unless I'm messed up and somehow missed where he wrote that).
If you have the L-48, then you should do just fine on regular unleaded 87 octane.
If you have the L-82, then it would be iffy in anything but 89 or higher unleaded.
Either engine greatly depends on how the engine is tuned. You can make an L-82 run fine on 87 and you can make an L-48 need 89 or higher if the tuneup isn't right or at least in the ballpark. The altitude where you are also plays a part. High elevations don't need as much octane.
I suggest that you try the lower octane and see how she does.
Originally Posted by gerry72
Not quite, Carl. The octane tolerance threshold difference is in the compression and cam. And your power numbers are wrong for '73.
Originally Posted by carl a
190 hp and 225 instead of 180 and 225 sorry i hit the wrong key
I use the hi-test
Since having mine I have used the expensive stuff, lots of good threads on this topic (cause' I looked at them when I had the same question) using the archive search function. Have at it and take a read.
Location: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Originally Posted by c3andc5
I use Super Unleaded...never less then 91 Octane. Your Q-Jet will appreciate it.
Originally Posted by Mike Ward
All '73s were designed to run on regular unleaded gas, irrespective of displacement or horsepower ratings.
Fred
Hi Russel,
Welcome to the forum! Another Aussie...thats awesome
Im from Sydney.
Congrats on your new vette...it looks real nice (your avatar pic?).
Im still waiting for my vette to arrive..I don't think it has left Los Angeles yet!
When your vette arrives, post us some pics! and tell us more about it.
Im sure you will have alot of fun with your vette. Look forward to hearing more about it.
cosmicvette
Im from Sydney.
cosmicvette
