Turn-around for Motor Work/Exhaust LPE C6/C5
St. Jude Donor '03 & '05
What is the average turnaround at LPE for an engine redo (402/427?) and cost? I know there web has prices but if you dropped off a C6/C5, how long before you got it back, and cost?
Check out thier website or give them a call. According to thier C6 427 page, normal install time is 4-5 weeks for a sleeved 427 NA package. http://www.lingenfelter.com/pack_cor_c6_427dt.htm
The 402 is only 3 weeks. http://www.lingenfelter.com/LS2C6402CID.htm
Give Jeff or Ed a call up there and they will be more then happy to answer all your questions. 260-724-2552
Jersey
Jersey
From pick up at my house in Reston Va to LPE completed the heads/cam package to return to my house was 3 weeks and 4 days 8 hours and 20 minutes (missed MR BLU )
Michael
Michael
Z51 6 spd... very impressive gains and at about 4500 rpm up to 7000... (as per the dyno...have not done yet due to wanting to do a 200 mile break in of the cam etc.) numbers just keep climbing over stock...where things are dropping off at about 6000 on stock LPE setup is just climbing and climbing... I have taken to 6500 rpm runs (quick up then cool down) and wow this car moves...not that the stock C6 doesn't but now it is in rare performance territory. Very driveable, no cam looping at idle and just a great upgrade. Unfortunately I am out of town so not driving my Vette . Also the sound with the Corsa sport and X pipe is very very cool...deep throaty and a WOT ... I will post the pre and post dyno results. LPE was great to deal with, took care of MR Blu and install was flawless...and the bonus since they upgrade the drive pully no worry about damn thing falling off They also reduce the torque management intrusion...that makes for a big diff.
Michael
Michael
Hi Steve40th-
We are currently scheduling cars about 3 weeks out, and we would need your car here for 4 weeks to do the stroker package. What we do is have you put your deposit down when you schedule the job so that we can start on the heads, rotating assy. Etc. before the car gets here.
As an example, if you scheduled the job next week(5/16/05) we would have the car back to you by 6/24/05. If you are on a time crunch, I will make sure we meet whatever deadline you are working under.
Please feel free to give me a call if I can answer any questions for you,
Thanks!
Ed
Thanks!
Ed
Michael
Michael
Here be the LPE Head & Cam package:
2005 Corvette LS2
6.0 L Engine package
500 BHP / 440 lbs-ft of torque
Package includes:
Engine removal, inspection and cleaning for assembly
Lingenfelter CNC ported & polished LS2 cylinder heads
2.02 / 1.57" one piece stainless steel intake & exhaust valves
Three angle valve job, hand blending of valve seats
CC chambers, surface, set spring heights and assembly
Competition Cams valve springs
Lingenfelter designed Competition Cams hydraulic roller camshaft
Modified LS2 oil pump assembly
Lingenfelter ported & polished throttle body
Low temperature thermostat
Corsa stainless steel cat back exhaust
ASP underdrive pulley system
All necessary gaskets, fluids & bolts
Professional assembly & engine installation
Engine testing & expert ECM tuning
Chassis dyno testing before & after installation
Lingenfelter 2 year / 24,000 mile warranty
Lingenfelter
Michael
2005 Corvette LS2
Package includes:
Lingenfelter
Michael
Hi Michael I'm interested in the same package from LPE. Just wanted to see if you had an update. Also a few questions are you worried about the clutch holding up and did you lose any low end power or throttle response compared to stock? Thanks in advance
Rob
Rob
Have the first c6 lpe did with package have an auto car is very strong , I have ran 12.34 at track on stock tires. car could be much better at start but once it gets moving it is a beast. I have spoke with gram and has learned or found some things is his program that shood help low speed throttle response. my car should be back to them in about two weeks to re program . they have been great to work with.
that seems like a lot of money
Jersey
Jersey
Originally Posted by Mr.clean
Does anyone have an opinion of Lingenfelter vs. Callaway or Mallet. The prices are pretty different but Lingenfelter seems to give the most hp per $. What is the difference?
Originally Posted by c6 corvette Z51
for around 5k you can get a supercharger cant you?
Lpe 500hp
I hsve a cam lope with my LPE head ans cam package, not bad . you do know it is there. Still waiting to really test the car. Went to the track once ,got 1 run --not good-- forgot to turn off A/c. LOL. Will try to run in Aug. ---I better get good results for the money spent.
Mine's pretty well done - finishing touches put on from what Tim's told me. They've had it since end of May, so about 4 weeks looks to be their install time now, though I know they got in a good load of cars just after mine and got a little backed up.
