[Z06] What are you guys doing for front tires?
I just ordered my new wheels for my coupe. I got z06 size wheel but there are very few choices for fronts in the 265/40/17 tire. I went with 255/40/17's in the BFG KDW2's and 295/35/18's on back. I am frustrated that there are not more 265..Anyway, what do you guys do when you need tires?
Thanks
-Ken
Thanks
-Ken
I had the same problem.....I wanted to swap my rear 18's to the front, but they are to wide??? I will leave it as standard now and lower the car to make the wheels fit the arches better.....
I think 265's are best..for the front...dont mess with and other combos!!
TireRack have some good people to talk too and the best prices
St. Jude Donor '05-'06
I was running Kuhmo ECSTA 275 40 17s. They are a bit wider, and very damn sticky. Down side is they throw a ton of debris on the car. I have put 10K on them and had no issues. I have not had them to a HPDE yet. Good luck and I think my next set will be the MXs, and I saw they make a 265 40 17 and a 315 30 18.
Dave
Dave
I needed front tires due to an alignment issue. Since I had some of the negative camber removed in the process (I hate to admit it but I drive much more in a straight line than in circles) I replaced the OEM GY F1 with the GY F1 in a 275/40/17 size from Tire Rack. All I can say is WOW. I personally like how the car feels. It doesn't wander anymore and the front end seems more planted even in corners. Guess the slightly wider tire offset some of the cornering grip/feel whan I had all that camber.
BTW I don't track it.
Tom
Tom
Dave
Dave
Thanks
-Ken
Thanks
-Ken
Thanks
-Ken
Thanks
-Ken
