[Z06] Want new wheels for the Z, But is there any reason I cant just put 18" rims on all 4?
Old 04-27-2005, 02:56 PM
Internets_Ninja
Internets_Ninja's Avatar
Received 1,282 Likes on 843 Posts
Default Want new wheels for the Z, But is there any reason I cant just put 18" rims on all 4?
I was just thinking my Z06 would look better with 18 inch rims on all 4 corvers. I want to go with either black with polished lip Z06 replicas, or the Chrome Z06 replicas. MY Z06 is black and I think the chrome would look great, but I cant decide between the 2 yet lol.
Anyhow, why do we have 17 inch rims on the fronts?
Would I have to go to 19s in the rear to put 18s on the front?
Thanks
-taz
Old 04-27-2005, 03:06 PM
Evolution
Evolution's Avatar
You can do 18's all around, or 18's front and 19's back. I like the better ride from the 17's in front personally with the 18's out back. I had 18's all around for awhile. 18's on the front were a bit to ruff for me for a nice street car. Not out of the question though by any means, just where I am with the car right now.
I have black motorsport wheels. Check with Bob from the House of Wheels, he has great prices right now.
Old 04-27-2005, 06:17 PM
Internets_Ninja
Yup, Houseofwheels is actually about 15 minutes from my house.
I wonder if he can install them too or if hes just a warehouse.
Old 04-27-2005, 06:27 PM
hocheehoba
hocheehoba's Avatar
Has 18 x 9.5 on front and 18 x 10 on rear.
Old 04-27-2005, 06:29 PM
TTRotary
TTRotary's Avatar
I wouldn't get 18 fronts for the following reasons:
1. decreased brake torque - this is noticeable.
2. tires cost more - a lot more.
3. bigger wheel=Increased unpsrung weight
3. cosmetics - rear wheels look smaller than fronts because there is more body around them. I am convinced that is why the rears are one size larger anyway, stock. There is certainly no practical reason for it.
Old 04-27-2005, 06:37 PM
Pumba
Support Corvetteforum!
Pumba's Avatar
Jason,
I have chrome Z06 wheels for sale (17 x 9.5 front and 18 x 10.5 rear). PM me if you are interested.
Old 04-27-2005, 09:53 PM
Yellow-Z06
5th Gear
Yellow-Z06's Avatar
Just Wondering Where You Got The Rear Spoiler (what Kind Is It?) And How Much For Rims And Tires?
Old 04-27-2005, 10:00 PM
Yellow-Z06
5th Gear
Yellow-Z06's Avatar
Pumba, How Much For Rims/tires?
Old 04-27-2005, 10:42 PM
POWERTOWEIGHT
POWERTOWEIGHT's Avatar
I have as 02 Z06. Factory size is 17 x 9.5 front & 18 x 10.5 rear. I installed Hickock 18 x 9.5 front & 18 x 11 rear. There are no clearance issues but make sure that the rolling diameter of any new tire is as close to original as possible. this is key.
Old 04-28-2005, 12:30 AM
cnationshb
cnationshb's Avatar
that's a carvaggio rear spoiler
Old 04-28-2005, 06:55 AM
Pumba
Pumba's Avatar
YellowZ06,
Only the rims are for sale. PM me for details.
Old 04-28-2005, 09:00 AM
Wah
Wah's Avatar
Stock 18x10.5 on all four
Old 04-28-2005, 02:07 PM
B R
B R's Avatar
Location: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
I was gonna say #2 & #3. #2 won't really be a lot more, but it will be some more .
Old 04-28-2005, 07:44 PM
Innovator
Innovator's Avatar
Why would there be decreased brake torque if the circumference was the same?
Old 04-28-2005, 10:23 PM
FixedRoof
FixedRoof's Avatar
Cruise-In VI Veteran
Hey man... what size tires are you running on the front with the 10.5s? Any rubbing issues?
I'm running the 18x9.5/18x10.5 combo.. with 275/295's...
Steve
Old 04-29-2005, 07:38 AM
Hardtop01
Hardtop01's Avatar
Thanks
-taz
I'm interested in buying your fronts if you go with new wheels. Check PM.
Bruce
Old 04-29-2005, 08:20 AM
EV2DEMON
EV2DEMON's Avatar
I'd take issue with everyone of these points actually.
1.Decreased brake torque- The 275/35/18 front tires I have are the exact same diameter as the factory 265/40/17 tires. Why would braking be any different?
2. Tires cost more- I guess I can't argue with this, but If I were worried about spending an extra $100 on tires every couple of years, I probably shouldn't have bought a Z06.
3. Bigger Wheel=More unsprung Weight- True in some cases, but if you buy the right wheels, the weight difference is minimal, and in some cases you can even loose weight with an aftermarket setup. The less expensive 1 piece cast wheels are usually heavier, but a pricier custom wheel like a Fikse, CCW, or HRE is not only light, but far stronger than the factory wheels. I went with CCW modular wheels, and the weight difference was less than 2 pounds up front.
4. Cosmetics- My opinion is the complete opposite of yours. The factory 17 inch tires have huge sidewalls that give them the illusion of being taller than the rears. Going with 18's all around made the fronts more proportioned to the rears, and the car looks much better now.
To Want new wheels for the Z, But is there any reason I cant just put 18" rims on all 4?
Old 04-29-2005, 08:49 AM
C6~Missle
C6~Missle's Avatar
By not keeping the stock tire size ratio the same, I would think you would throw off the active handling system since it depends on the wheel speed sensors. It won't get the true input when the system is activated due to different wheel/tire sizes..
Old 04-29-2005, 08:51 AM
EV2DEMON
EV2DEMON's Avatar
That might be true, but I also suspect there is an acceptable range the AH can work within as well. For me it was a non issue, both the 275/35/18 and 335/30/18 tires on my car are the same diameter as stock.
Old 04-29-2005, 10:02 AM
HP_Addict
HP_Addict's Avatar
I agree with all points, especially with #4. It looks better to have equal or greater sidewall in the rear. Also traction control will not be affected if you keep the diameters close to stock. Some guy shave even ran the same diamter front and rear at the track without problems. I just order 18" CCW Classics for my car. 275/35/18 front and 335/30/18 rears.
Quick Reply: [Z06] Want new wheels for the Z, But is there any reason I cant just put 18" rims on all 4?
