Cross drilled brakes?
Old 03-24-2005, 10:10 AM
1990z51
1990z51's Avatar
Default Cross drilled brakes?
Does anyone know if the cross drilled brakes with the Z51 package provide a performance advantage or do they just look cool?
Would it be the same for Z06?
1990z51 is offline
Old 03-24-2005, 10:13 AM
Another Yellow
Another Yellow's Avatar
St. Jude '03-'04-'05-'06
Just looks.
Another Yellow is offline
Old 03-24-2005, 10:14 AM
YellaFella
YellaFella's Avatar
All cross Drilled/Forged rotors just look cool.
YellaFella is offline
TommyV
Support Corvetteforum!
TommyV's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Cross drilling is mostly cosmetic. Under severe use, cross drilled brakes can crack. Slotted or dimpled is better.
TommyV is offline
Old 03-24-2005, 10:22 AM
Mighty-Mouse
Mighty-Mouse's Avatar
Fact or Fiction: Drilled/Slotted rotors improve braking
http://forums.corvetteforum.com/show....php?t=1024509
Sorry there's just to much to re-type
Mighty-Mouse is offline
Old 03-24-2005, 10:23 AM
Alex Levy
Alex Levy's Avatar
Correct they can crack however CAST "drilled" rotors are much stronger. They are cast with the whole pattern from the get go and not drilled after the fact thus not sacrificing structural rigidity. They also serve a very decent functional purpose but are extremely expensive
Alex Levy is offline
Old 03-24-2005, 10:25 AM
BEZ06
BEZ06's Avatar
Take a look at this posting in the Tech Section:
Brakes: Compilation of Threads
Click on the first thread about drilled and slotted rotors and you'll get a wealth of info on the issue.
Bob
BEZ06 is offline
Old 03-24-2005, 10:26 AM
Alex Levy
Alex Levy's Avatar
Wow there is a ton of misinformation in that thread.. the only viable ones are the ones who pasted from Stoptech and to a point wilwood (who's standard non-race brake kits mind you are total crapola).
Bottom line.. CROSS DRILLED Rotors are for Bling
Old 03-24-2005, 10:43 AM
jazzlove
jazzlove's Avatar
Location: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
Looks only, per Dave Hill...
jazzlove is offline
Old 03-24-2005, 10:48 AM
AC54ME
AC54ME's Avatar
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
AC54ME is offline
Old 04-03-2005, 09:06 PM
2005ArcticWhite
2005ArcticWhite's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'18,'20-'21,'24
They LOOK Cool:
2005ArcticWhite is offline
Old 04-03-2005, 09:10 PM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
They do look cool. Obviously, a lot of people think so, that's why GM has to put the Z51 on restriction. I don't think they planned on selling so many.
Datawiz is offline
Old 04-03-2005, 09:11 PM
Curtis A. Franz
Curtis A. Franz's Avatar
lets dimension that a bit better. The cross drilling does nothing for better stopping. However, the Z51 package also has bigger diameter rotors that do contribute to better stopping.
Curtis A. Franz is offline
Old 04-03-2005, 09:16 PM
Datawiz
Datawiz's Avatar
CI-7-8-9-10 Veteran
Good point. And they look cool too!
Datawiz is offline
Old 04-03-2005, 09:41 PM
yell01
yell01's Avatar
CI 7-8-9-10 Veteran
Originally Posted by 2005ArcticWhite
They LOOK Cool:
...really cool!
yell01 is offline
Old 04-03-2005, 09:58 PM
Alex Levy
Alex Levy's Avatar
I think thats true and untrue.. Let me explain..
I dont believe the Pad surface increased between the Z51 and the base. The rotors are larger but the pads arent. While the larger rotors help with cooling, unless you are doing a SLGP (Stop Light Gran Prix) on the street you shouldnt be heating the brakes up enough that it makes a difference in stopping Track use it probably helps a BIT but due to the cross drilled rotors on the Z51, a bit of hard track use and they will crumble.
Old 04-03-2005, 10:23 PM
natejohn
natejohn's Avatar
Wouldn't the "swept area" be larger due to the increased diameter?
Also - wouldn't the "leverage" increase due to the outer portion of the larger rotor rotating at a slower speed?
Also - wouldn't the "heat sink" factor be less because of the extra material?
Of course the larger rotor is heavier.......(but still looks cooler)
natejohn is offline
To Cross drilled brakes?
Old 04-03-2005, 10:28 PM
Alex Levy
Alex Levy's Avatar
Not really.. Braking occurs when material touches material. (As basic as that sounds).. If the pad surface doesnt increase with the rotor you might actually be hurting the performance because you are adding unsprung weight. (Not sure if this is the case as i havent measured Z51 vs NON) but if you go with a larger rotor and dont add more pad surface you are adding more unsprung weight and not making it "Worth While" by not increasing material to material contact. The heat sink factor shouldnt really occur during normal street driving or hell even during "Spirited" driving. If you cook your brakes on the street, you are doing something illegal
Old 04-03-2005, 10:41 PM
offshore
offshore's Avatar
I want a set of those rotors...help
offshore is offline
Old 04-03-2005, 10:57 PM
GGWOODY
GGWOODY's Avatar
Location: Buena Park, CA I seem to have left my electrolytes with your daughter
Though cross-drilling looks cool...Also helps to keep rotors cooled down under intense conditions. More exposed surface area = more heat transfer potential/capability.
GGWOODY is offline
Quick Reply: Cross drilled brakes?
