Just installed brass headlight gears (pics)
At first my driver’s side headlight would only come halfway up and I would have to get out of the car, turn the headlights on then manually pull up the light. After a few weeks it would not even go up or down at all. I decided to order some new brass gears. After much research I decided to buy them from www.bfranker.badz28.com
The gears from bfranker do not use the stock rubber inside the gear. Good thing, because when I pulled out the stock gear and it was fine! But the rubber bumper was destroyed! With bfrankers gears you don’t have to retain the stock rubber bumper. In this picture you can see the good stock gear on the left on the bad one on the right, also notice it broke the plastic tabs inside the gear that keep the rubber bumper from spinning:
Pic of the stock gear and stock rubber bumper:
Picture of bfrankers gear:
Installed:
Rodney Dickman's gear:
Installed with rubber bumper:
I would go with bfrankers, because with his gear it eliminates the rubber bumper. On 97-99 Corvettes the motor case unbolts with 3 bolts, but on 00+ they are sealed and with bfrankers kit he even includes the epoxy to close the motor case as does Rodneys. I am not ******* on Rodney’s gears, but I am just letting you guys know what else is out there. Bfrankers kit is $43 shipped for one gear kit, or $81 shipped for two. The install only took about 45 min and they work perfect now. More info and instructions for bfrankers gear can be found here:
http://www.bfranker.badz28.com/headlightfix/index.htm
The install is almost the same as the 93-97 Trans Am in the instructions.
Info for Rodneys gear:
http://www.rodneydickman.com/corvette.html
Patrick
Installed:
Patrick
Good post and pics..thanks!!
Mine haven't failed but I imagine they will eventually so I'll be saving this post as one of my collection of DIY "tech tips".
MONARTOR
I already had one of mine repaired under warranty.
I agree. This is one of those write ups thats going in the archive. Thanks for taking the time to record it.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I and a WHOLE bunch of others here have rebuilt ours with Rodney Dickman's brass gears. I choked when the dealer quoted $300 to buy and install one new headlamp actuator. These are a much better option.
Thanks for the info. I just bought some euro headlights from a forum member and he told me that I'll want this mod. He said the extra weight of the euros makes the lights bounce against the nylon gears. The things you learn here are amazing.
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I know they made changes to some years (like my '03) came with aluminum end links instead of the previous nylon end links ... anyone know if they may have changed the gears or are mine still nylon? I'm thinking about getting the brass gears before my headlights fail.
Received 19,234 Likes
'20-'21-'22-'23-'24
Thanks for the info. I'll keep it on file for future reference.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT INFO!!
I have the Rodney Dickman gears installed, and no complaints so far, after about 8 months.
I AM a bit disappointed with myself that I didn't install the gears when the first gear broke. My passenger plastic gear broke while the car was still under warranty, so I let the dealer put in a new motor. That new motor raises the headlight faster than the old motor, so instead of a vroooom-thunk, I get vroooom-thunk-thunk when the head lights open. It's just a little annoyance, but you all know the feeling as nit-picky owners...it just bugs me.
Originally Posted by Vettlldo
What year is your vette and is this a usual problem with all C5's over time?
mine started acting up a few months ago, so i ordered the brass gear, then i read that u can rotate the the shaft and use the other half of the nylon gear,(since it only uses one half of the gear and not the whole thing) saw this fix on ls1 forum, that worked great for a few months, then that stripped also...just put the brass gear in the other day and all is well....
