Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- Corvette: Why is My Check Engine Light On?
Guide to diagnose trouble with recommended solutions.
Fill up & get the "Check Engine Light"?
Over 4700 miles on my C6 without any real trouble. However, after filling my tank this evening, I received the "Check Engine" light along with the message "Service Fuel System" on the DIC. "Ok, I guess I didn't properly tighten the gas cap..." so I checked - it was tight. I removed it and re-tightened. Same error message. During the short 8 mile drive home, the DIC alternated between "Service Fuel System" and proper operation and the fuel gauge alternated between full and empty (in sync with the DIC.) Once home I shut down, inspected the gas cap & filler neck but could find nothing wrong.
Since I haven't purchased a scan tool yet I can't check the error code tonight. I guess I'll have to take it to the dealer in the morning
Has anyone else experienced this behavior?
AveryOBX - No, C6 was off during fueling.
Braced - No OnStar.
need1 - Interesting.
We'll see what the dealer has to say later today...
Thanks for the input!
Braced - No OnStar.
This is well documented within the forum. I had this exact same thing happen at 250mi and it was a FSU. The dealer needs to replace it, make sure his has one in stock BEFORE he removes the tank or you will be sitting without your car for up to a week.
I have the same problem. My dealer had to order a left sending unit. I am still waiting for it to come in. Including yours and mine that makes at least four C6's that have had the same problem. This was a problem that was not uncommon in the C5
Wow, the C6 can self-heal!
Went to the dealer this morning but their service dept. was closed. So, I continued with my day running errands. After about 35 miles and the fourth start, the check engine light no longer illuminated and has not returned.
Yes, it is possible that I overfilled the tank since I always give the pump an extra shot to make sure it's really full (not a crappy pump shutting off early.)
I'll go to my regular dealer (near my office) on Monday and have them check to codes to find out what really happend.
Thanks to everyone for your quick suggestions and pointers!
Best regards,
-Mark-
Best regards,
-Mark-
I have been topping of to the point where the fuel will spill out of the cap.
Best regards,
-Mark-
Best regards,
-Mark-
Best regards,
-Mark-
Best regards,
-Mark-
Don't let the dealer remove the tank without having the FSU in stock. He can check it using the codes without tank removal. I waited 7 days with the tank sitting on the floor of the shop waiting for a FSU to arrive.
I think you will find that as soon as you fill your car the problem will be back until you burn some of the gas off (I found that if the tank was 1/2 full or less the problem disappeared).
Yep, I am still waiting for the part to come in, it has been two weeks now. I called GM this morning trying to see what I could do to get this matter moving and really did not get any where. My '03 was bought back by GM under the Lemon Law, I sure hope this is not going to turn out the same way again. I did not think lightning could strike twice.
Was this covered under warranty? I have the same problem, but my 3 year 36K warranty expired in November 2010. I think it might be covered because the check engine light is on.
Check engine light comes on in my 2000 Corvette after fuel level reaches 1/2
My problem is just the opposite. My check engine light comes on just about the time I reach the 1/2 full point and below. It goes out after a few miles after I fill up. The code says evap. emmisions.
This never happened until I had the fuel level sending unit(s) replaced. I have a 2000 Corvette, and they had a problem with the gas guage reading empty as soon as it hit 1/2 tank. ABout six months after the sending units were replaced, the problem began, and I have now had it for years.
I'm guessing an air leak somewhere, but I have no idea where to start looking. Any thoughts?
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Forum Rules .............
Existing threads receiving no replies for 45 days or more.
If an existing thread has not received a reply for a period of 45 days or more, members should create a new thread which is identical or similar in nature, rather than to post to the existing one.
Moderator
Received 3,570 Likes
