Name the problem
Old 03-16-2005, 05:35 PM
Pipedreams
Pipedreams's Avatar
St. Jude Donor '06-'07
Default Name the problem
I have a noise coming from the engine compartment / front dash area. The best I could describe it is a low pitch whine. it only happens driving between 2000 and 3000 rpm. it happens both driving and if you rev the motor to 2000 you can also hear it. Its very faint but can be heard in the car. any ideas 425 miles
Old 03-16-2005, 06:42 PM
Lowlead
Lowlead's Avatar
I have the same situation, mine sounds like it's more towards the passenger side of the dash/firewall area. Only happens above 2000-2100 rpm and light engine load (city cruising in 3rd gear). To me it sounds like it's a vacuum dashpot resonating. Maybe one of the a/c or heater control devices???? It doesn't really sound associated with the drivetrain, more like something mounted to the firewall or under the dash.
Old 03-16-2005, 07:16 PM
Pipedreams
Pipedreams's Avatar
I agree, did not hear it for the first 200 miles and then started to hear it. I thought it might be vacuum related because of the rpm's. I need to get my son to work the gas so I can explore that area, keep in touch
Old 03-16-2005, 07:46 PM
catbert
catbert's Avatar
Name the problem
Let's call it Skippy
Old 03-17-2005, 06:24 AM
Pipedreams
Pipedreams's Avatar
OK anyone else with this problem or know the what it is?
Old 03-17-2005, 08:00 AM
C6FirstVette
C6FirstVette's Avatar
A/C on or off? HVAC on or off?
Michael
Old 03-17-2005, 09:03 AM
rushguy
rushguy's Avatar
I have the same thing and I also have it in my CTS-V, it is much less audible in the Vette. If they are both the same it is from the heater core, GM was aware of the problem since June of 2004 on the V and still has no fix. I'm no expert and could be wrong but I recognized the sound right away and I've been living with it for months so its a good guess.
Old 03-17-2005, 09:34 AM
drmotorhead
drmotorhead's Avatar
replace mufflers with straight pipes = no more dash noise
Old 03-17-2005, 09:51 AM
Pipedreams
Pipedreams's Avatar
This is IT!!!! what is the resolution?
Thanks
Old 03-17-2005, 10:39 AM
rushguy
rushguy's Avatar
There is no resolution as of yet for the Caddy, engineers still working on it. I remember when i first brought it in after I got it Caddy had no clue what it was and then someone pulled that bulletin up. I would imagine Chevy either has no clue, knows about it and hasn't released a bulletin or will know about it when enough people start telling them about it. I can tell you what they told me and that is there is no danger to the car, its basically harmonics. Its annoying but not in any way damaging, turn on music or have windows open and can't hear it. Drive with no music and windows closed and once your attuned to it, it can drive you nuts.
Old 03-17-2005, 11:30 AM
Lowlead
Lowlead's Avatar
Yep, that describes my problem exactly. Great information..Thanks!!
Old 03-24-2005, 10:40 PM
Pipedreams
Pipedreams's Avatar
Anyone else with this problem?
To Name the problem
Quick Reply: Name the problem
