Lifting Pucks
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Slip how? With the weight of the car? I just bought the Elite Engineering ones and used them twice already and they are awesome, especially for the price. I may buy another set to use for paperweight cause they look so good!
Originally Posted by 3XBlack6spd
they dont "slip" they have that tab that goes in the hole under the car.
Originally Posted by ROJ#79
I'm looking for vinal or plastic covered pucks, so they won't slip.
Does antbody know a vendor that has these?
Download the file below and save yourself a bunch of money:
http://member.newsguy.com/~rmoburg/j...ft%20pucks.doc
A better way to go is to get a rubber pad insert for your jack. About $10 at Harbor Freight. You might need to jack something else that needs cushioning occasionally and it will come in handy.
Originally Posted by 12stepvette
Make a set of your own for 5 bucks...4 hockey pucks with 1 inch eye bolts run through the center. They use the tie down slots and twist in place.
I have the same set-up they work great
What type of jack are you using? I just purchased the same pads from Elite Engineering ($39 for a set of 4) and haven't received them yet. How much clearance do you have from the ground with these pads installed? I have a Craftsman professional jack 3.5ton with the large (4" I think) dish on the lift arm and would like to know if that'll work or whether I need to buy a special jack. I know my car is 5" off the ground.
Thanks for your help!
Scott
Scott
Scott
Scott
They don't slip on the car, it's possible for the pads to slip on the steel arms of a lift!!!!!!!!!!!!!!!!!!!!!!!
I imagine if you off-center the end of the lifting arm on the puck enough, it could slip. But like most, I double check this operation a few times before I lift.
Scott
Scott
