Crank pulley TSB report
Former Vendor
St. Jude Donor '06
I spoke with our shop mang. today on this problem. I don’t know if this info has been posted or not but according to the TSB only those VINs that are before 55111039 are affected by this problem. The fix is simple just a washer needs to be installed unless the pulley has come off and has damaged the crank then it is a diff. story.
Former Vendor
St. Jude Donor '06
Originally Posted by bangbgC6
I'm pretty sure that there is also a new bolt as well, the old one is to be overtorqued to press the pulley onto the cranksnout. The old bolt is then removed and the new bolt installed and torqued to the correct specification.
That is my VIN
Former Vendor
St. Jude Donor '06
Originally Posted by hawaiianswiss
Do you also have any info on how many of these "washer kits" have been installed on all possibly affected cars?I`m trying to see how many c6 really have the problem. You might be able to find out from GM?
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Rick....help!!!!!!!!!!!
Former Vendor
St. Jude Donor '06
Originally Posted by Datawiz
Mine has been at my local dealer in Ft. Myers, FL for 1 WEEK!!!! They just told me today at noon that they are waiting on the washer, but they have all of the other parts. Do you have access to the required washer? If so, I'll pay to overnight it. This is crazy!
Former Vendor
St. Jude Donor '06
Originally Posted by MThomas
So do we have to wait until we have a problem to get the fix or what??? Thanks for any info!
CI-7-8-9-10 Veteran
I am sure it would be a ordered part for us as well.
Thanks, I'm going to call Kerbeck again (where I got it) and see if they have one in stock. Waiting this long for 1 washer is unacceptable.
CI-7-8-9-10 Veteran
Kerbeck says the Part # from the TSB that C-5 TECH posted is NOT a part #.
WPC Part # 305
Desc = Washer, Crankshaft Balancer
qty = 1
How are they going to fix our cars if they don't know what the heck to order????
WPC Part # 305
qty = 1
WPC Part # 305
qty = 1
WPC Part # 305
qty = 1
CI-7-8-9-10 Veteran
Doesn`t you dealer know the part#?? What has your dealer ordered 1 week ago? Maybe GM thinks the customer has to know part#??
I just called, he's at lunch. I will call again in a little bit.
St. Jude '03-'04-'05-'06
.......I can say we have not fixed any with the problem and we work on alot of Vettes.
WPC Part # 305
qty = 1
WPC Part # 305
qty = 1
