Changing all fluids yourself?
This spring before I get to th track and stuff I wanted to change all the fluids in the car (yes including the blinker fluid for you smart-a$$es). I've done plenty of oil changes before, but what is involved with our rear end/transmission?
Any help appreciated.
OK, it works, so I will retype my reply.
For the small amount of money, it is mucho easier, cleaner, and faster to have someone with a lift do it. I had the tranny done on Wed. and I imagine the diff is more of the same.
There was a thread on this last week with tips. Good luck.
Premium Supporting Vendor
I change out my tranny and diff fluids routinely. It is really pretty easy.
To start, I bought a set of Rhino Ramps from Walmart and put the car up on those using jack stands as backup.
The tranny (assuming manual) drain plug is on the lower rear corner, passenger side. The fill plug is about 2/3 the way up on the driver’s side. Tranny takes a DEXRON III fluid. You’ll need about 3.5-3.75 quarts.
The diff drain plug is on the center bottom. The fill plug is on the rear face upper right. The diff uses 75w90 synthetic lubricant. The diff may also need a bottle of friction modifier if chatter occurs. I don’t use it and don’t have chatter. It will take about 1.75 quarts.
You’ll need a hand pump to get the fluid up into the tranny and diff.
I use AMSOIL ATF in the tranny and AMSOIL recently came out with a new Severe Gear Extreme Pressure 75w90 Gear Lube that I will use this year.
AMSOIL ATF
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
AMSOIL Hand Pump
AMSOIL Slip-Lock Differential Additive
AMSOIL Preferred Customers save about 20%:
AMSOIL Preferred Customer Program
AMSOIL ATF
AMSOIL Hand Pump
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
with Subdriver..it is easy to do just takes a little time but besides knowing you added the right amount etc. it also gives you a chance to inspect the underneath part of your car clean out radiator etc.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a very handy tool that you can use to get the new fluid back in the trans and tthe rear.
It's like a giant IV bag for your car. You fill it with the fluid of your choice and squeeze the bag.
BC
BC
Originally Posted by PDQC5
Are you sure about the differential requiring synthetic oil? I didn't see any reference to that in the owners manual.
Please advise
Please advise
My 98 book is different, maybe the Z06 diffs require the syntheric oil
From the 2002 Owners manual page 7-20. Rear Axle (Limited-Slip Differential)...SAE 75W-90 Synthetic Axle Lubricant....With a complete drain and refill add 4 ounces (118ml) of Limited-Slip Axle Lubricant Additive.
I use Redline so it already has the friction modifier in it. But I highly recommend the Amsoil pump. You can attach it directly to a 1 gallon milk jug that you've cleaned and filled with the tranny fluid of your choice and pump it in with little or no mess. Super easy.
