Build Your Own CLB
Build Your Own CLB
If you can solder, you can build your own. I just did...cost me $25 for parts! PM me if you're interested.
John
http://shelor.net/Z/CorvetteForum/Cscokd/
John
Location: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
John
John
You should get a Job at GM , Looks like You could Teach a GM Electrical Engineer something . (really)
Veteran
Originally Posted by Dan_the_C5_Man
Finally! Someone else that understands basic electronics!
Cscokd is willing to share this info with forum members and you were not!
Been running my CLB now for several days....no column lock, no codes and my DIC is happy The CLB is a pretty simple device to simulate the column lock motor and send back a signal to the BCM to indicate that the command was executed. $50 for the aftermarket CLB seems a bit steep considering there's probably only $15 in parts and $10 in labor. I have a schematic, parts list, and the beginnings of instructions that I will email to CF members that want it. I also have access to parts since I'm in the Silicon Valley, so I can help you with that as well if needed. Now, if I only had a hosting website so I could post pictures and attachments on here....grrrr.
John
John
Originally Posted by ersatz928
I submittted my version of the DIY CLB to the forum C5 tech tips, but it was never added. I wonder why?
Ok....SpeedyZ (thanks Dale!) was good enough to host my files and also convert to .pdf for those of you that don't have Power Point. I've had an overwhelming response asking for the files. You guys are fearless when it comes to mods! Well, here you go:
St. Jude Donor '03 & '05
