63 Build Update Pics
We finally got the headers made and mounted with the sidepipes. There is just a little bit more grinding before they go off to the chrome shop. The bodywork is almost finished and we set the body on today to check fit and ride height. We expect the car to settle about one more inch when finished. It sure is exciting to get it to the point where it looks like a car.
Thanks, the fenders are from Corvette City. They are 2 1/2 inches wider front and rear, which let us run 11 inch wide wheels front and rear.
Darin
Darin
BITCHIN COOL ! ! ! !
Rich
Rich
They are. I wanted Hooker collectors with Hooker sidepipes. I called Hooker to see if they would make a set for me and the guy laughed. We looked at all kind of options and then Doug Rippie from DRM said he would modify stock Hookers to fit my LS2. He did an amazing job.
No apology necessary. Just messing with you. It looks incredible.
I'm running a Maggie HotRod unit on mine and it fits perfectly under the L88 style hood and rocks. You're gonna have a blast.
Another awesome looking resto mod. I personally like the big fenders while keeping the body lines in place.
When you decided on which frame to use, what led you to choose the Newman frame? I am planning a Grand Sport on modern chassis and trying to decide which frame to use.
Jeff
Jeff
Jeff
Jeff
If I were doing another one I would go with R&R out of Montana. Their frames are modified originals to take all of the C4 suspension (similar to Newman). They built the frame for my 56 Belair and are going to build one for my 54 Olds Holiday Coupe. They do both C1 and C2 frames and the workmanship is awesome. Excellent lead and delivery times, a pleasure to deal with and less expensive than Newman.
Jeff
Jeff
FYI, Tim at Vetterod's is doing all of the paint and bodywork as well as the final assembly. Highly recommend him and his shop. They do everything from NCRS restorations to restomods.
Darin
Great look! The wide fenders maintain the stock body lines. Will the stock bumpers fit? Looks like the car is sitting pretty good, what springs did you use? I changed both front and rear springs and added the lowering shims to mine and would like it a little lower still. I love the wheels! Please tell me more about them, size, offset, who made them, etc? They look like the 5 spoke Americans from the period. I am looking to replace the C5 wheels on my 66 coupe but haven't found anything I like, til now!
Thanks,
Nick
Thanks,
Nick
