How to find out if car is z51 option
Old 07-22-2007, 10:31 PM
av8instyle
av8instyle's Avatar
Default How to find out if car is z51 option
I have an 84. What is the easiest way to find out if it has the z51 option? Thanks.
Old 07-22-2007, 10:37 PM
C4boy
C4boy's Avatar
Look on the RPO tag and see if it says Z51
It's the white decal with a bunch of 3 character codes - under your armrest lid or under one of the rear compartment lids.
Old 07-22-2007, 10:49 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
If your RPO list is missing from the console cover, the Z51 option included heavy duty springs, shocks, stabilizer bars and bushings, quick ratio steering, engine oil cooler and an extra radiator fan. While some of these parts could be ordered without the Z51 (oil cooler and HD radiator) and others could be added by a previous owner, the steering ration would be the hardest to change. I'm sure someone here can tell you how to find out which one you have.
hippy
hippy's Avatar
That seems just way too damn easy. Is there a harder way?
Old 07-22-2007, 11:03 PM
GIMMESOME
GIMMESOME's Avatar
It's actually not that easy,you have to reach back there,raise the door,and read
Old 07-22-2007, 11:06 PM
av8instyle
av8instyle's Avatar
Yeah, thanks. I did that. It's not in any of those places. I assume you mean when you push the button to open the lids it is right there in plain view. Or do you have to dig further? Either way, I looked at all three lids and under the hood and I can't find it.
Were they specified in the VIN?
Old 07-22-2007, 11:13 PM
GIMMESOME
GIMMESOME's Avatar
Sorry,to answer your question,no the RPO's are not in the VIN#.
If they are not under any of the lids,they have probably been removed.
You would have to order a duplicate.Sometimes there is a build sheet stuffed under the seat,or glued to the fuel tank.
Old 07-22-2007, 11:18 PM
av8instyle
av8instyle's Avatar
Just to clarify: a z51 definitely has the extra fan? Would the extra fan be in plain view? Right with the other fan? I only have one that I can see easily. Sorry for the weak questions. I'm new to the generation.
Old 07-22-2007, 11:19 PM
C4boy
C4boy's Avatar
Those are the only 3 places I've ever heard a C4 RPO tag being placed. I don't know what can be broken down by vin#. There's a really well laid out RPO FAQ on www.c4guru.com and one here
This is what the tag looks like.
Old 07-22-2007, 11:30 PM
Z-07 freak
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
Do you still have all of your teeth?
Old 07-23-2007, 12:27 AM
JrsTurn
JrsTurn's Avatar
Feeling froggy? The guy's asking a legit question.
My car didn't have the RPO sheet either. If your steering wheel turns more than 1 3/4 turns (I could be wrong about the exact #) from stop to stop, it's not a Z51. I'm thinking mine turns 2 1/4 or somewhere close. Someone will chime in with the correct number for you, I'm sure.
Old 07-23-2007, 01:18 AM
sick-punk
sick-punk's Avatar
well holy monkey *****, i just check the rpo in the old girl and it turns out that mine has the z51 option. so what exzactly does that do great thread
Old 07-23-2007, 12:15 PM
av8instyle
av8instyle's Avatar
Thanks for the tip. I checked my steering and I got almost 2 and 1/4. I guess no Z51 for me. Thanks again.
Old 07-23-2007, 12:36 PM
champs65
champs65's Avatar
Also, if you know for certain that your wheels are original, you will have 8.5 inchers up front and 9.5 in the rear. Specific to 84 only, I believe.
Old 07-23-2007, 01:11 PM
Z-07 freak
Z-07 freak's Avatar
Old 07-23-2007, 02:50 PM
c4cruiser
c4cruiser's Avatar
The secondary cooling fan will be infront of the radiator. Look up under the front license plate at the air intake and if it has the fan, it will be in plain sight.
In '84, over half of the production run came with Z51 Here's a link to the available options and their cost.
If you want some nice documentation for the car, you can get copies of the build sheet and the window sticker from the National Corvette Museum The build sheet is what followed the cr down the Assembly Line to tell the workers what to install on the car. The window sticker will show the base price, the optional equipment and the final MSRP of your car. It will also show the name fo the dealer that got the car.
Just give them your VIN and you will get the pages. Get them laminated for display
Old 07-23-2007, 06:13 PM
scooter18155
scooter18155's Avatar
Crawl under your car and look at the markings near the ends of the springs, if you do have Z51, you will see:
Front: 'BMB', the part no is 14045782
Rear: 'BMH'. part no. 14045786
if its got the standard gear, you will see:
Front: 'BMA', the part no is 14045781
Rear: 'BMF'. part no. 14045785
this is only true if you have an 84 different year cars had different codes on the springs depending on the spring rate. you can also measure the dia of the sway bars, check the # of turns on your steering wheel. i wouldnt judge by rim size oil cooler or how many fans too easy to change that stuff and some is not z-51 specific here is a link to a chart that has the sway bar dia and spring rates.
http://www.corvetteactioncenter.com/...usp_chart.html
To How to find out if car is z51 option
Quick Reply: How to find out if car is z51 option
