Cantan 7qt oil pan - proper oil level? (picture)
Old 08-15-2005, 05:27 PM
ericcer
ericcer's Avatar
Default Cantan 7qt oil pan - proper oil level? (picture)
In the picture below I have 7 qts of oil poured into the pan. As you can see I have poured oil into the filter as well. Is this the ideal oil level? The reason I ask is because the stock dip stick is inaccurate with this pan.
http://www.knology.net/~eac/images/oilpan.jpg
Old 08-15-2005, 05:48 PM
FoolCrzy
FoolCrzy's Avatar
same question here...
Old 08-15-2005, 06:24 PM
Pete K
Pete K's Avatar
I have the same pan. The chick at Canton told me the 7 qts is total system capacity. She said in a new motor(mine was) put in 7 1/2 qts. After motor is run, and oil drained, fill with 7 qts. I did this and my dipstick was accurate. I did not fill the pan. Didn't think to do it or I would have.
Old 08-15-2005, 06:33 PM
ericcer
ericcer's Avatar
It woulds seem that it could stand a 1/2 qt more. Still I would think that you would not want to fill it where that crank would be splashing in the oil.
It has been a few months but it seems that when I put in 7qts in the engine with that pan that the dip stick read low.
Old 08-15-2005, 07:23 PM
lead foot 85 vet
lead foot 85 vet's Avatar
Mine reads 1 quart low.......the add mark.....with 7 quarts, stock dip stick....................I can live with that, just tell anybody changing your oil or they'll over fill it....well some do run 8 quarts.
Old 08-15-2005, 08:22 PM
Zix
Zix's Avatar
Install the pan...level the car...pull the overflow bolt out...fill the engine with oil until it starts coming out of the overflow hole...wait until it stops and mark the dipstick and that will be your new full mark.
That's what I did and I've never had a problem.
Old 08-15-2005, 09:07 PM
ericcer
ericcer's Avatar
That is a good idea. Anyhow, I updated the picture to include a 7.5 quart fill. I like the 7.5 fill.
Old 08-15-2005, 10:14 PM
96GS#007
96GS#007's Avatar
Received 1,812 Likes on 1,089 Posts
You want the oil below the windage tray, otherwise the crank picks up the oil.
The Canton windage tray is lower in the pan than the factory windage tray in the factory pan using the dipstick as the reference point. That's why, when filled as shown in your 7qt pic, the oil level will appear to be 1/2 qt low on the factory dipstick but is actually correct.
Old 08-15-2005, 10:38 PM
tjwong
tjwong's Avatar
Is the 7 qts including what is in the filter?
Old 08-16-2005, 05:57 AM
ericcer
ericcer's Avatar
Yes
Old 08-16-2005, 07:17 AM
luvmy92
luvmy92's Avatar
Exactly! When we tested it with water that turned out to be 6 qts. Then with the oversized filter we figured another qt. So, with 7 qts in her she reads about a quart low with the stock dipstick... which is your new full mark.
Mike
Old 08-16-2005, 07:51 AM
tommelton
tommelton's Avatar
Then trim about 3/4" off the top of your dipstick fill tube, and your dipstick will then read correct.
-Tom
Old 08-16-2005, 11:50 AM
artvette
artvette's Avatar
-Tom
I like your thinking. A mini tubing cutter and zip...zip.
Old 08-16-2005, 05:33 PM
ericcer
ericcer's Avatar
-Tom
Good idea and I wonder if you could get a longer dip stick that would work too.
I just checked and the top inch or so of the dip stick tube is a larger diameter so I guess cutting it off would not work.
To Cantan 7qt oil pan - proper oil level? (picture)
Quick Reply: Cantan 7qt oil pan - proper oil level? (picture)
