Z51 VS. base plus Z06 swaybars
I have a Z51 on order but now am rethinking this. Will I notice much if any difference if I just get the base suspension and put on some heavy duty sway bars, (perhaps like those on the new Z)? I dont track the car at all and I'm sure this would significantly improve my wait time. I do want the "sporty" handling feel...
If you were to buy a base car, improve the suspension, add trans and oil coolers, change the rear gear ratio, and improve the brakes you would spend a bunch more $$ than just buying the Z51.
Originally Posted by RandyMi
What tranny are you getting?
(I will be putting on headers, catback and intake)...
If you are getting the MN6, my advice go Z51, and leave the car alone!!
You can't dial it in any better then factory.
But, heres why I ask:
1) The car I ordered was a loaded coupe but the dealer is small
2) Dealer will sell me the car at GMID - But only if delivery is this winter
3) Likelyhood of a small dealer getting a Z51 allocation is very low and wait time is high
I definitely DO want to buy at GMID - so in order to make this happen for certain, I have to eliminate the Z51 option. (I could wait and hope, but that may mean not getting a C6 this year at all) Accordingly, I'm trying to determine if the Z51 difference for somebody who doesnt track the car is worth waiting a year for....(and yes- to save 7500, I would wait rather than buy now at sticker). Is the acceleration difference of a MN6 Z51 THAT noticable vs. MN6 non-Z51?
Presuming my dealer got an allocation and I got the car, I would agree.
Good luck!!
This is a thought but you can put in 3.90 gears and sways and be about even on price with the Z51. This will actually get you better gearing because the base car gets a closer ratio transmission. This puts the car at nearly the same gearing as the Z51 in 1st through 3rd and 6th. Fourth and fifth are lower. Much better out on the road in my opinion. This is what I did since the only thing I wanted from the Z51 was the gearing. Having said that If I wanted the Z51 I would have got it regardless of the wait. You can get one from Kerbeck (last I heard) for 3k under msrp so that would be another option.
Originally Posted by EB20003
What will changing gears do to his factory warranty on his brand new car?
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by RacrX
Make it stoooooooooooooooop!!!
Pssssssssssssst.....................hey buddy................................you wanna buy some sway bars?
Psssssssssst...................hey buddy......................wanna buy some sleep-eeze?
About as close to nothing as you can get. The only part of the warranty that would be in question would be the stuff thats directly affected by the part. Not a lot of stuff. As to the gears themselves, they seldom break when broken in correctly and they also come with their own warranty. The only way they would know is if you told em. Even if they were in your diff I dont think one in a thousand techs would count teeth. I sleep fine. And enjoy having the better gearing without the gap of the Z51 box. As always folks should make up their own mind about whats right for them. My very first words, "This is a thought" Get it? Here is something to think about, an idea, something to consider....
Changing the ring and pinion in a brand new car?????
Who do you take it back to when or if the gears start making noises???
Right. I'm not to likely to do that..
Expecially if you are buying an extended warranty. IMO a much better investment over the long haul, on an all new C6 model Vette than a set of aftermarket gears.
Originally Posted by joeking
I would find a car already built. :thumbs Why wait?
Originally Posted by MSammet
"The road of life is only just so long."
Let me get you a set..............come on...............all your buddies are gettin 'em.
