Originally Posted by Face
I find that hard to believe. I went from 3.15's with a SY3500 to 3.73's with the SY3500. The 3.73's maybe took another tenth off my E.T. With a stock converter the gains would be more, but no way .4-.5 tenths, that's converter territory.
Originally Posted by doubledeuce
Yeah, I would, but I heard that there is A LOT of labor involved with installing a convertor, is that true, and how much does the labor cost?
I dont know about how much labor costs as I know local guys who do work for me. |
If you only had the money for one iteam I would say 100% go with the convertor. It makes such a big difference that the ring and pinion is of no matter. If if was a M6 then its all in the rear end ratio but with a A4 it's all convertor. A 3.15 rear is fine if you mate it with a good convertor, just ask the people who have tried it, the will tell you that there is very little difference with changing the rear gear.
The labor should only be slightly more, if not the same.
then how many hours of labor will it take? my local corvette shop had scared me to not doing it, because they said it will require 10 hours of labor. :eek: . And I know how long it will take to swap the gears, I done it before, its around two hours.
Just a heads up, $500 seems like the going rate for the swap(not including the rear R&R). |
