Does anyone make 305/40/17 tires?
I would like to stick with 27" diameter tires (approximately). I can find 275/50/17's but nothing bigger. Is that all there is?
Re: Does anyone make 305/40/17 tires? (BBShark)
But a 275/50/17 is 27.8 inchs tall.how much taller do you want to go,plus thats an 11 inch wide tire too.i have alot of pages saved on tall tires let me go look.also heres a tire chart http://www.sstire.com/tireheights.html
[Modified by patsnitrovette, 4:48 PM 1/17/2004] |
Re: Does anyone make 305/40/17 tires? (patsnitrovette)
a buddy of mine is running 335/40/17's on his GT stang
Re: Does anyone make 305/40/17 tires? (Corz)
also
305 45 17 ----------27.81 |
I want to go wider not taller. I would like to stick with a 27 inch diameter to fill out the wheel well. Right now I am thinking about 275/50-17 in the back and 245/50-17 in the front. I would really like to go wider in the back but cant really find much. I will check the 335's. Do you know what brand the Mustang tires are?
I cannot find anyone making 335/40's or 335/45's x 17. I have to ask this again, does anyone make a tire wider than 275 in a 17 that is about 27 inches in diameter. If there is, please let me know the size and the manufacturer.
The tire size 315/35-17 there are some, one of the supporting venders carrys several different tires. Also if you call them they may have other options for you.
http://www.discounttiredirect.com/di...do?step=search |
Re: Does anyone make 305/40/17 tires? (Tominator)
The tire size 315/35-17 there are some, one of the supporting venders carrys several different tires. Also if you call them they may have other options for you. http://www.discounttiredirect.com/di...do?step=search |
Re: Does anyone make 305/40/17 tires? (bigblockbob)
You can run a 10inch wide rim with 315/35/17 ....offset trailing arms would be the way to go ....and no fender flares required ....Feb 2004 had a nice 69 with offset arms running 315/35/17 rear ....If you want a picture I,ll find it and post ...
Re: Does anyone make 305/40/17 tires? (White 68)
yes, will the american racing torque thrusts work still??
will the handling be the same? what is the sacrifice with offsets?? |
TTT :seeya
The tallest 17's that i ever owned were 285/40/17 Good year F1 Z rated steel. I don't think that they make them anymore, but i've got a set with half the tread.
You can run a 10inch wide rim with 315/35/17 ....offset trailing arms would be the way to go ....and no fender flares required ....Feb 2004 had a nice 69 with offset arms running 315/35/17 rear ....If you want a picture I,ll find it and post ... |
