How do I 'set' the TPS and IAC...93 LT-1 ?
Someone mentioned they set their TPS and IAC and their car has never run better. I asked them how to do it, and they never responded back.
Recently I put a new TPS sensor in, at WOT the new TPS registered 4.06 volts which showed 99% throttle position on my Auto XRay scantool. However, my old TPS sensor showed 4.62 volts at WOT and 99% throttle position on my auto xray. I figure I might be 'ok' because it still shows 99% throttle (somehow my ECM learned that 4.06 volts meant WOT) However, I am still curious as to how one 'sets' both IAC and TPS I should mention my car always seems rich, with its current mods, at idle. I have a 93 LT-1 w/hot cam kit, ed wright chip, LT headers, no cats. Any help would be appreciated, Dave |
Re: How do I 'set' the TPS and IAC...93 LT-1 ? (dizwiz24)
I think your TPS is the same as the one on my 92. In which case, it is non- adjustable. According to the Helms, it is self zeroing (0% open at idle) at .3-.9v. ...it does mention that if a new TPS is installed, the TECH 1 unit (@ the dlr unless you just happen to have one around the house :D ) will reset it for ASR functions.
[Modified by ittlfly, 10:28 AM 12/20/2003] |
The methods for setting IAC & TPS are on my site (link in sig. below) but, as mentioned, your TPS is not adjustable though the ECM still uses OBD-I.
Beginning in '90, even if you cut adjusting slots into the TPS mount the ECM will simply override any "tweaks". |
Re: How do I 'set' the TPS and IAC...93 LT-1 ? (65Z01)
65Z01 I cant see your signature, can you post the link.
diz, TPS is not adjustable as mentioned earlier. However IAC is adjusted by the following. Pg 6E3-C2-5 (VIN P):
The IAC valve can be reset by doing the following: depress accelerator pedal slightly, start and run engine for five seconds, then turn ignition "off" for ten seconds. |
