ZO6 clutch price
First, what is the difference between the clutch in a 2001 coupe and the clutch in the ZO6 ? Second, I need to relace mine, who gives the best price. I think I want to stick to a factory set-up.
Re: ZO6 clutch price (Gee3)
I don't have the specifics other than an 02 and newer Z06 clutch has a higher clamping pressure than the 01. The 02 and newer clutch is $499.95
Edit - please no direct links to non-supporting vendors. TR
The Z06 has a higher clamping force and better slave cylinder than the earlier C-5s. The Zo6 Clutch is the way to go if you want to keep it stock.
GM PART # 12570806 DESCRIPTION: FLYWHEEL package this flywheel package comes with the following: flywheel, pressure plate and clutch disc.-----this kit is designated for 2001-2003 corvette Z06 equipped with the LS6 engine with MM6 trans. We have the Z06 Clutch package in stock $303.59 Z06 Hydraulic Clutch Main Cylinder/Rod Part number 12564455 Z06 Clutch Slave Cylinder/Actuator # 12562767 Send us an e-mail if we can help http://WWW.GMPartsDirect.com :flag [Modified by GmPartsDirect.com, 2:43 PM 10/29/2003] |
Re: ZO6 clutch price (GmPartsDirect.com)
some one posted in the for sale section last week for an entire ZO6 clutch set for a bit over 300 shipped, you may want to do a search
Re: ZO6 clutch price (Monster231)
Anyone have any idea what the labor cost on install is??? And coould you put it on a 99' MN6
[Modified by RangerBarrow, 10:53 PM 10/29/2003] |
Re: ZO6 clutch price (RangerBarrow)
I was quoted 5-6 hours labor. I don't know if that is reasonable or not. Yes you can use the Z06 clutch on the '99. If your going to do it, upgrade the master and slave cylinder as well. If you have a problem with your slave cylinder down the road, it will cost almost as much as replacing the clutch.
