Average cost to dyno tune a car.
I know not all cars are the same but what is the normal. I want to get my fuel pressure and timing all dialed in..
TIA Rich |
Re: Average cost to dyno tune a car. (Corvette0096)
Ive seen them run from $30 for 3 runs to a couple hundred for a tuning session.
I know not all cars are the same but what is the normal. I want to get my fuel pressure and timing all dialed in.. TIA Rich |
A typical price would be around $100 per hour. Some places will break it down and not make you pay for a full hour if you don't use it.
Re: Average cost to dyno tune a car. (Nathan Plemons)
Around here dyno shops are around $100/hour + $25/hour for Wideband O2 if you want it. That is if YOU are doing the tuning. If you have them doing the work to your car there is another $60 or so an hour.
Re: Average cost to dyno tune a car. (scorp508)
Dyno-Tech in Ft.Wayne,IN a supporting CF vendor charges $150 per hour
THeir rates are posted on their website, whihc can be seen on the left column of this web page. [Modified by ld85, 10:46 AM 8/29/2003] |
Re: Average cost to dyno tune a car. (ld85)
I bought my own wideband 02 meter for about $460 from techedge.com and I will tune for max power at the strip.
Re: Average cost to dyno tune a car. (ericcer)
Found a local place to do mine with a wideband 02 with 3 pulls and tuning for $180.
Better be good to get it tuned in 3 pulls.
Ouch that seems high. You're going to get 1 baseline pull, 1 pull with changes to see how it likes it and a final one to either correct the mistake made in pull 2 or hope for a little bit better if 2's change worked.
What tuning would they do for 60/hr? Don't you just adjust your fuel pressure regulator until the A/F ratio is where you want it?
Re: Average cost to dyno tune a car. (sothpaw2)
What tuning would they do for 60/hr? Don't you just adjust your fuel pressure regulator until the A/F ratio is where you want it? |
I was todl that they woudl usea Romulator, WB-O2 and chassis to do 90$ of the tune, then they would drive on teh street too.
Their web site says 2-3 hours avg., but they would not give me a $$$ limit, he said " its done when it's done" I asked would $1000 do it and he said mayeb yes, maybe no! So needless to say Ol'RJ has been burning the chips with the assistance of SKI, but I see a dyno run in the future 1-2 weeks. $75 for 3 - pulls or $100 unlimited pulls in 1-hour. http://www.extremeperf.com/ |
