procharger vs. vortech
i am looking into getting a supercharger and i've already decided i dont want the magneson, however i've narrowed it down to:
ati's procharger and vortech sq trim. i know there are various intercooler combinations and different s/c head units, but i want to know what people think is the best of the two....i've heard good and bad about both and from my research personally i am leaning towards the vortech. any help is appreciated... - evil :reddevil |
Re: procharger vs. vortech (EVIL)
Call Andy, he has lots of experience with both.
Re: procharger vs. vortech (HIGHRPM)
I also live in Austin and have a procharger (I could help you out if you need some help during the install...).
I would go with the procharger again, since it so dam simple and pretty much has all the bugs worked out at this point. There are also quite a few procharged c5s in the 10s now. I'm not saying the vortech can't do it, just that the ATI kits are a little more proven. |
Re: procharger vs. vortech (QuickSilver2002)
i talked with leonard at auto-tek here in austin and he said the vortech is a better system. hmm...anyone else? evil :reddevil
The debate that never ends! :boxing
I chose ATI, but I'm sure Vortechs are good too. Get what you like, and don't worry about what anyone else thinks... Mike M |
Re: procharger vs. vortech (LS1 Bird)
My tuner had both systems for me to choose from. He recomended the Vortech even thought the install was more involved for them, he said they are much more reliable and no S/C belt slippage as compared to the ATI. :cheers:
Re: procharger vs. vortech (racer44)
I'm not a guru on this but some people may want quietness and the Vortech SQ G-Trim on the ???standard LS1 system??? has the sleeper effect down pat. The upgraded T-Trims make some noticable whistling.
Air-air aftercooling (ATI) vs. air-water aftercooling (Vortech). In virtually all reasons imaginable, I'd favor air-water aftercooling. Two exceptions that would make me favor air-air aftercooling would be reliability (if your cooler water pump breaks, then your engine is in danger; my Vortech aftercooler water pump broke on my '95 T/A kit, may be resolved now) and possible advantages in road racing conditions (as long as you avoid prolonged drafting). |
Re: procharger vs. vortech (STAGED)
Isn't the vortech air-water-air ? Not just air-water. Water is used as a transfer medium only.
Re: procharger vs. vortech (boblackhardtop)
Vortech should be a bit quieter and more reliable with less belt issues.
ATI should have more peak power but more headaches, ie: radiator & many more potential belt problems. ATI would be better for road racing than the Vortech if any SC should be used for roadracing for that matter. |
There are also quite a few procharged c5s in the 10s now. I'm not saying the vortech can't do it, just that the ATI kits are a little more proven. were talkin heads cam built bottom ends the other one has a 383 stoker HEADS CAM with an ati and NOS TOO !!! so there is much much more to getting into the 10s with an ati... |
Re: procharger vs. vortech (MelloYellow)
My ATI is plenty reliable. No belt slippage issues or anything else so far, just problems with traction. :D My tuner liked the ATI best, but I think that tuners develope preferences just like everyone else. You'll have to decide which system you like best and go for it. I personally went with the ATI because it made more h/p and didn't require drilling the oil pan, which makes it easier to return to stock if I ever decide to sell (which is not likely but never say never) :cheers:
ATI would be better for road racing than the Vortech if any SC should be used for roadracing for that matter. -Jake |
hrm ... exactly how much longer is Vortech even going to be a player in the SC game though.
Re: procharger vs. vortech (tattooed)
re: Why Vortech not good for road racing? The Air to Water cooler builds heat and loses efficiency after long use whereas the Air-To-Air Intercoolers don't suffer this continued use problem. Only would see this with road racing, not street driving.
tatooed: Why you think Vortech is getting out of the SC biz? |
There are also quite a few procharged c5s in the 10s now. I'm not saying the vortech can't do it, just that the ATI kits are a little more proven. the 2 ati cars i know of in the 10's had extensive" other" work done as well were talkin heads cam built bottom ends the other one has a 383 stoker HEADS CAM with an ati and NOS TOO !!! so there is much much more to getting into the 10s with an ati... BTW, I think opticz06 just got into the 10s with a bolt on ATI car with forged pistons. http://forums.corvetteforum.com/zerothread?id=614763. He may have more, but I think he indicated that was it (he was not using the 30shot on this run). |
Stick with the air to air intercoolers, they are more efficient,require less maintenance, and a lot more reliable (no pumps,no hoses,no need to add ice).
Re: procharger vs. vortech (Devil Dog)
can't go wrong with eitherone. But I would prefer ATI because it come with standard intercooler, where vortech is extra $.
Bruce Cog set up is coming by next week 93LT1 Conv w/ZF6 Blown D1-SC/N2O ARE built 383ci/Stage II heads http://www.burtronics.com/myvette/bv1.jpg http://www.burtronics.com/myvette/bv2.jpg http://www.burtronics.com/myvette/bv4.jpg |
Re: procharger vs. vortech (Bruce)
The Air-Air intercooling is more efficient according to several studies that I read. Unfortunately, I no longer have the information because I made the decision quite a while ago. Another advantage of the ATI is that the oil is self-contained (NO tapping the oil pan).
ATI belt slippage? Not at 7psi. If you want to get into the 10's, I would follow OpticZ and get forged pistons, Lunati Rods, and ARP bolts. The parts aren't that expensive. . .don't know about the labor. By the way, we aren't talking barely into the 10's. If he pulls a decent 60' time, he will be running mid-10's easy. :thumbs: :cheers: :thumbs: |
i talked with leonard at auto-tek here in austin and he said the vortech is a better system. hmm...anyone else? evil :reddevil Just found their website. http://www.autotekinc.com/ls1.shtml Wow, those prices look a little insane. 10k for a ls1 crate motor :eek:, I hope those prices are a misprint. [Modified by QuickSilver2002, 11:07 AM 8/3/2003] |
