How many 03 Z06's were made?
Anybody know how many 2003 Z06's were made?
Just wondering, Tim |
Re: How many 03 Z06's were made? (C54TIM)
i *think* it was about 8,635 units or 24% of the entire model run.
Here are the numbers I have seen for 2002 and 2003 Z06 production.
2002 Z06 2003 Z06 Option Code / Description Qty % Qty % 8297 23% 8635 24% 12U Silver exterior 1467 18% 1089 13% 21U Electron Blue 1814 22% 1272 15% 41U Black exterior 2205 27% 2599 30% 70U Torch Red exterior 1746 21% 1967 23% 79U Yellow exterior 1065 13% 1708 20% 19I Black interior 6734 81% 7200 83% 70I Red interior 1563 19% 1435 17% 1SA Package Option 01 8254 99% 8613 100% AAB Memory Package 7794 94% 8241 95% AR9 Seats - Euro 8297 100% 8635 100% B84 Body side moldings 4780 58% 5408 63% FE9 Federal Emission 6040 73% 6544 76% GU6 Rear Axle ratio - 3.42 8297 100% 8635 100% MM6 Manual 6 speed 8297 100% 8635 100% CJ2 Air Cond. w/auto temp 8297 100% 8635 100% UN0 AM/FM Stereo CD 8297 100% 8635 100% V49 License Plate Frame 4838 58% 5315 62% UV6 Heads Up Display 0 0% 0 0% Z06 was 23% of production in 2002 and 24% in 2003. Sorry about the format, my copy paste from Word did not work well. If you follow the numbers and percentages on each line the first series is the 2002 production and the second series is 2003 production. John :cheers: [Modified by Silver JD, 6:58 AM 8/1/2003] |
Re: How many 03 Z06's were made? (Silver JD)
why do you have 0% for the HUD option?
[Modified by WisconsinVETTE, 3:33 PM 8/1/2003] |
Re: How many 03 Z06's were made? (WisconsinVETTE)
HUD in 2003 was 100% (Standard Equipment) :yesnod:
Re: How many 03 Z06's were made? (COOL COUPE)
HUD in 2003 was 100% (Standard Equipment) Sorry about that, I don't know who put together the original table but it is a typical question. Cool Coupe has the correct answer. John |
I heard that in 2001, convertibles were 15% of total production and Z06 was less than 5% of total production.
By 2003, one Corvette in four was a Z06 (25% of production). That is all I know. It might be close to right, it might not. dave |
Interesting info, HUD should be 100% in '03 though.
Re: How many 03 Z06's were made? (Arizona Z)
Interesting info, HUD should be 100% in '03 though. |
Check this out: http://www.corvettesbyrickdaniel.com...onnumbers.html
Re: How many 03 Z06's were made? (PowerMad)
'01 Z06 production was 5773 out of something over 35K cars.
Re: How many 03 Z06's were made? (gasman29)
Rick's site was the source of my numbers. I believe he got his numbers from the C5 Registry.
John :cheers: |
Wasn't the HUD standard equipment in 02 as well? I almost positive it was.
Re: How many 03 Z06's were made? (DDSLT5)
Wasn't the HUD standard equipment in 02 as well? |
Re: How many 03 Z06's were made? (rbartick)
Obviously HUD is part of Package Option 1. HUD was not available separately, only through the package. :conehead
