How to remove rusted exhaust manifold studs?
I recently receive a matching numbers exhaust manifold in excellent shape. My thanks go out to Dabo for that, thanks David! However the studs are very rusty and need replaced. I have soaked the studs in WD40 for a couple of days now. I am paranoid about breaking the manifold trying to remove the studs. I'd appreciate any good recommendations ya'll might have.
Thanks, Rick in Tennessee |
Re: How to remove rusted exhaust manifold studs? (Rick Church)
If you have a torch you can heat them up. When they get hot, you can put a set of vice grips on them and slowly work them back and forth.
I would use a penetrating oil instead of WD-40. Also heat the manifold, since it will expand more than the studs. I was able to pull all the studs out of my 77 this way.
Mike |
Re: How to remove rusted exhaust manifold studs? (mfendley)
yes the blue flame wrench(torch) will help
Rick,
I have found that PB Blaster or Kroll work better then WD-40 |
If you can't get them out and end up breaking them off then you can carefully drill down the center and through each stud with a small diameter drill bit. Then gradually step up the size of the bit untill you are just under the the diameter of the threads. Then you can hook and peel the end of the stud thread that is siezed towards the center of the hole. Next grab the thread end with needle nose pliers and start twisting, this will wind the remaining thread around the plier jaws. I was able to do this on all three studs on one of my manifolds after the studs broke off and easy-outs failed to work. It takes time but it does work, just keep the hole centered. :cheers: :smash: :smash:
Re: How to remove rusted exhaust manifold studs? (jetech)
Use heat and a good penitrating fluid like the others said, WD-40 doesn't work well as a rust buster. if you do break the stud weld a nut onto the stud and work it out that way.
Steve :steering: |
Look in Popular Mechanics for a penetrating oil called KROIL or SILI-KROIL.
I believe it is made in Tennessee. Your old crew chief would probably know about this stuff - they use it for cleaning collectives. This stuff really works. http://www.kanolabs.com/ :steering: :cheers: :steering: [Modified by shawn_cake, 1:21 PM 4/20/2003] |
Silicroil and aerocroil is made by Kano Laboratories. Thought I had a bookmark for their web site but don't. Do a search for Kano and it should come right up. Got all of mine out by heating the snot out of the manifold. When it gets a dull red you are good to go, have at them with a vice grips. You won't get it done with a propane torch, need an oxy/acetylene. Good luck! :cheers:
Re: How to remove rusted exhaust manifold studs? (stpman)
Use heat and a good penitrating fluid like the others said, WD-40 doesn't work well as a rust buster. if you do break the stud weld a nut onto the stud and work it out that way. Steve :steering: |
