Windsheild wiper motor wiring for a 1971
Does anyone have a 1971 or 1972 and a digital camera? I took appart my wireing harness and wiper motor and well I am not sure about the configuration of the wiper wires and some stragglers from my harness. Some picutres would be very helpful to me.
I have a flat wire harness ...........connected to what I think is the right plug Red wire with single spade ......... Green wire with single spade......I assume is case ground Blue wire with tube connector........ Yellow wire with tube connector....... and about 4 others that are not wiper motor related. I have a schematic and it helps a bit but amny other the other wires I am trying to figure out just are not very clear what the are for or from. Any pictures with engine wire will help me especially if you have a 1971 with the LS6 option with AC. Thanks guys! Ron |
Re: Windsheild wiper motor wiring for a 1971 (71LS5)
Ron,
You will have mail shortly! Let me know if these pics help. If not, shoot me back an e mail with more details as to what pics you need. |
Re: Windsheild wiper motor wiring for a 1971 (shoptek)
Marc, thank you for the pictures. I am not sure they help me much as your motor looks different than mine. Also it has the wire colors covered by the plastic wire protectors. Is that the original motor? Do you have a yellow and blue wire with a tube type connector going to the top of the motor?
The blue and yellow wires go to the washer pump.
