couple of questions on wheels/ tires
I'm thinking of doing the zr1 style wheel/tire thing over the winter. Right now I have 275/40/17s on standard 1991 9.5 inch sawblades. (1) Should I go with 11 inch on the back? Will they fit okay? Will the same 275/40 tires on the front 9.5s fit the 11s in back or are we talking two different tires? Any discussion on this subject is appreciated as always. Thanks! :yesnod:
Re: couple of questions on wheels/ tires (brdd)
275's on 11" wheels is not a very good fit...i would recommend at least 305 out back....but might as well go with 315s
Re: couple of questions on wheels/ tires (kawboy5792)
will 11s fit in back okay without any modifications? Does anyone out there have this combination on a standard coupe?
Howdy,
I have that combo on my 89 coupe. 275 front, 315 back. You will really need to run the larger tire in the rear. the 275 will fit, but A: it'll look bad, B: the sidewall will not be square, and thus unable to do its job properly. C: handling will degrade. My car (see sig) is stock ride height and I have never rubbed with the 315s, and I have the "soft ride" suspension, so baby rolls a bit. :cheers: |
Re: couple of questions on wheels/ tires (Danno355)
what tires you want to buy and what conditions you drive in are the biggest thing to consider. make sure the tires you want are made in a 315, also if you live in a really really rainy climate you might like the 275 more. for the most part a 11" rim and 315 upgrade is a good idea, just do some homework on tire cost and think about how and where you drive first.
