10 Pounds Boost with provided ATI Pro Charger Pulley- Why
A question for those in the know. My 01 Z06 which was bone stock is at the tuners for a D-1SC Pro Charger install. The install went good with some fabrication work. TPIS LT headers were added as well as 42 LB Injectors. The problem is when put on the Dyno and out on the street she producted 10 pounds of boost.. The RWHP was a fantastic 579 RWHP however with the CR of the stock Z06 this would be a short lived experience with a chance of blowing the motor.
The existing pulley is the one that comes with the Pro-charger. 4 and 1/2 inch. Is it common for them to put out 10#s of boost or do I have some sort of restriction elsewhere? Of course ATI support said that it would be ok to run at that boost on premium gas but I dont agree with them. One bad batch and I am minus a motor. Anyway we ordered the 4 3/4 inch pully to get her into the 8 pound range and of course ATI was kind enough to overnite the exact same pulley thats on the car now :rolleyes: . So once again my tuner is going to call and attempt to get the proper pulley. While we are waiting for ATI to get there heads out of there ::cough:: can anyone shed any light on my situation. Why 10 pounds of boost on a supposed 7-8# pulley. The car was tuned with the LS1Edit and other then the headers is bone stock... Hoping to get this straightened out before the snow flys :crazy: thanks [Modified by Rookiedyn, 1:38 PM 10/11/2002] |
Re: 10 Pounds Boost with provided ATI Pro Charger Pulley- Why (Rookiedyn)
If I am not mistaken there are two versions of the SC. One for Z06s which produces 6.5-7 pounds and the other for Coupes / Converts that will get you around 9. Sounds to me like the regular C5 kit could have been installed, resulting in ~3 more pounds of boost.
Re: 10 Pounds Boost with provided ATI Pro Charger Pulley- Why (ZippoMan)
Hi ZippoMan.. Yes there are two versions the P-1SC-1 and the D-1SC . The D-1SC is identical to the P-1 but it doesn't come with the injectors or PCM program which I didnt want anyway because we have the 42 lb injectors and LS1edit. Even the P-1 comes with a 7 pound pulley and they say they have a 5 pound pulley available.
http://www.procharger.com/c5_press_release.shtml explained there. So I doubt I have the wrong unit installed. I imagine I will just have to wait for the larger pulley and see what happens. Worst case scenerio I will have to lower my compression to handle the boost but I didn't want to get into that at this time. I welcome any other input... |
I think your sizing is wrong.
Procharger P1 kit comes with a 3.8" pulley. On our D1 setups we run a 4.375" pulley which produces about 7psi on a stock Z06 @ 6000 RPM. The 7 lb pulley on a P1 would make about 12 psi on a D1. If you are running about 10psi, I would be very careful. I would suspect it started leaning out at high RPM and you really can only take about 10 degrees of timing with that much boost if you are lucky. |
Re: 10 Pounds Boost with provided ATI Pro Charger Pulley- Why (Mike Morgan)
I think your sizing is wrong. Procharger P1 kit comes with a 3.8" pulley. On our D1 setups we run a 4.375" pulley which produces about 7psi on a stock Z06 @ 6000 RPM. The 7 lb pulley on a P1 would make about 12 psi on a D1. If you are running about 10psi, I would be very careful. I would suspect it started leaning out at high RPM and you really can only take about 10 degrees of timing with that much boost if you are lucky. And I agree with your warning about running at 10 pounds. We arent going to do that thats why we are going through all the pulley swapping. 7-8 pounds max. Now its wait and see I guess.. |
Whats the latest at Kennedy's? did you get the boost down? :chevy
Re: 10 Pounds Boost with provided ATI Pro Charger Pulley- Why (z060ntrack)
You shouldn't have to measure the pulley as it has the diameter stamped on the smooth surface of the pulley. My stock pulley had 4.62 stamped on it and was exactly 4.62" in diameter. This produced about 5psi on my stock 02 Z06 with the D-1SC. I changed the pulley to a 4.25" and it increased boost to about 8 psi which is in line with what Mike at MM motorsports had replied that 4.375 was 7psi. Hope this helps.
Whats the latest at Kennedy's? did you get the boost down? :chevy I did get to drive her and the power is incredible. Spike the gas slightly in 4th gear while cruising and she will break loose the rear tires (traction is going to be my next hurdle). Problem is the p1514 code that puts the car into "reduced power mode". Bob is working on the tables with the LS1 edit solving the problem but I guess different variables can cause the code to trip. Frustrating waiting but I have all the confidence in Bobs ability to get her straight. |
Rookiedyn,
What was your actual pulley size before? I'm having a similar problem. Seeing 10psi with D1 4.25 pulley on an ls1 with similar mods. I have them sending me the 4.62 to hopefully bring it down to around 7. |
Re: 10 Pounds Boost with provided ATI Pro Charger Pulley- Why (QuickSilver2002)
Rookiedyn, What was your actual pulley size before? I'm having a similar problem. Seeing 10psi with D1 4.25 pulley on an ls1 with similar mods. I have them sending me the 4.62 to hopefully bring it down to around 7. Are you having any problems with the p1514 code putting you into "reduced power mode" on acceleration? This continues to be a problem for us. |
No problem with P1514. I had my programming done by Ed Wright in Tulsa and I'm sure he took care of that.
As many others have suggested, there is a table in the newest version of ls1-edit that should allow you to resolve this issue. It has throttle position on one axis and RMP on the other. The data values are the maximum expected airflow at the given RPM and TP. This was just added in the newest version of ls1-edit to resolve this exact issue. If you are still having trouble, I would suggest that you give Ed Wright (www.fastchip.com) a call. He does not work for free, but he is a great guy to deal with and he will resolve your issues quickly. [Modified by QuickSilver2002, 1:30 AM 10/11/2002] |
No problem with P1514. I had my programming done by Ed Wright in Tulsa and I'm sure he took care of that. As many others have suggested, there is a table in the newest version of ls1-edit that should allow you to resolve this issue. It has throttle position on one axis and RMP on the other. The data values are the maximum expected airflow at the given RPM and TP. This was just added in the newest version of ls1-edit to resolve this exact issue. If you are still having trouble, I would suggest that you give Ed Wright (www.fastchip.com) a call. He does not work for free, but he is a great guy to deal with and he will resolve your issues quickly. I am going to cruise up there tomorrow and take the car out and romp on it a bit myself. And then head back to the shop.. do a scan etc. repeat.. till the problem is 100% cleared. With a little luck I will be able to take her home after a long 4 week wait tomorrow with 176 extra horses at the rear wheels. :cheers: :smash: |
10lbs push harder.
