Antenna Replacement 94 vert
Where's the best place to get an ant. mast? Mine is starting not to go down all the way. It will retract if i help it, but not on it's own. I've tried cleaning it and it still stays up. I've put a switch on the ant. so i can keep it down when listening to the cd player. Once it is repaired will it work properly or is this problem something you just have to live with?
Hey, everybody waved today, evan had a C4 pull up and BS at a red light. thanks GP :cheers: |
Re: Antenna Replacement 94 vert (wz2wj1)
It should work fine when you replace it. Get a mast from any of the companies like ZIP or MAD. Its easy to do and cheap.
