I used SEM 39747 Multi-Purpose Panel Adhesive, you have to have to two part mixing gun. It worked great. I just completed the same repair.
3m part 8609 is listed as bonding Window glass to body
Originally Posted by Stewart's74
(Post 3713080)
Rod,
I rebonded the headlight support using 3M Super Fast Urathane Part# 08609. This stuff is awesome. I was instructed to use this stuff by a very reputable Vette restorer. He has used it for years with no problems. You can buy this stuff at any 3M dealer. I got mine at Advance Auto. Stew |
R16678 The post you referenced is over 13 years old.
Found the West product
Originally Posted by wydglydrydr
(Post 1576967161)
I recently did this same project. I had the rivet pops on the front end of my 72 I wanted gone. When I put it back together, I used West Six10. It's a 2 part mix that comes in a single tube just like standard caulk. It's mixed as it's dispensed. West sells a caulk gun designed for this tube, but you can make it work with a standard caulking gun. You just have to convince the tube to go into the gun. One tube was more than enough to do the header bar, cost me about $20, and I'm thrilled with it.
