Edelbrock fuel pump install on a 76?
whats up I just got some parts in the mail and Iam looking at this edelbrock fuel pump(1721)I got.It only has a 3/8 inlet for a line coming in and a line going to my carb My stock fuel pump has two rubber hoses going in and a fuel line going to my carb? I'am sure I'am not the only one to install this fuel pump to a 76, 350ci so does anybody know the way to change this over?What size fuel lines or fittings or anything else will I have to buy?I hate making 30 trips to the parts store and trying to guess what sizes and just what I really need.(everybody knows your on your own when you go to the stores)Any help with this would be awesome Thanks.Carver SLO RDE (76 L-48 vette)
Re: Edelbrock fuel pump install on a 76? (SLO RDE)
As a fellow 76 L48 owner I wish I could help but I can't so heres a TTT for you. :yesnod:
One line is a fuel return line. I believe you can just plug it, if you want to.
I just replaced my pump with a stock unit. Why did you go with the Edelbrock? [Modified by glen242, 11:00 PM 8/2/2002] |
The vapor return line can be plugged, but it's possible to have vapor lock problems with this setup. I have the same pump except for a BB and haven't had any problems as of yet. Are you still using the quadrajet? If so i was able to run braided line with it and the proper AN fittings to give it a profesional look but it did take a few trips to the speed shop. If you have any specific questions let me know.
:cheers: Pat Kunz |
I have a 72. I don't recall the part # of my Edelbrock pump, but it's the "street" pump. To fit the fuel lines I had to use the underside adaptor which costs extra. Both fittings are 3/8 90 degree. The line to the carb is routed to a Holley fuel pressure regulator. One outlet of the regulator is plumbed to the fuel return to tank line.
Re: Edelbrock fuel pump install on a 76? (AlwaysWave)
Where did you find the fuel pressure regulator? I may wind up having to get one. I ordered one fuel pump and got a slightly different one that may have too much pressure, 7 psi, I think.
Re: Edelbrock fuel pump install on a 76? (Eddie 96)
Where did you find the fuel pressure regulator? |
