Insulate THe Under Hood Fuse Panel?
Do You think this might help avoid the head lamp recall issue? Has anyone done this?
1 Attachment(s)
If your talking about the low beam lights going out, then insulating the fuse panel may help, but the real cause of that issue is a break in the ground wire for the headlight circuit. With enough circuit heat, the broken wire expands ever so slightly, and breaks the circuit, thus the lights go out. When the circuit is cold, they work fine.
The real solution is to fix the broken wire, or get a new fuse panel which will eventually have the same problem down the road. There is a DIY fix for the issue done with pictures by a forum member. I copied it and made a PDF from the data. The member who posted the data is mentioned in the PDF here is the thread http://forums.corvetteforum.com/c6-c...eadlights.html |
Originally Posted by LV2TOUR
(Post 1586911501)
The real solution is to fix the broken wire, or get a new fuse panel which will eventually have the same problem down the road. There is a DIY fix for the issue done with pictures by a forum member. I copied it and made a PDF from the data. The member who posted the data is mentioned in the PDF here is the thread http://forums.corvetteforum.com/c6-c...eadlights.html Appreciate any advise. Kevin T 😎🇬🇧 |
Originally Posted by KTVette
(Post 1588052340)
This is fantastic DIY step by step...cudos. Only one lamp intermittently goes out for me. It looks like one circuit operates both low beam lamps; if the case I most likely have a ballast going out. Thoughts? Last few night drives had no issues. It's hard to notice w/o getting out to look as I have ridiculously bright fog lamps on all time.
Appreciate any advise. Kevin T 😎🇬🇧 The fuse panel at the engine compartment: 1) I would check the fuses (19) & (21) to make sure they are OK. If they are OK, then 2) Then I would make sure that the low beam mini relay (47) is inserted all the way. Remove and re-install. If there is still an issue, then it's probably the bulb, which I suspect you checked, or the ballast. Good Luck :cheers: |
(Post 1588054490)
If only 1 of your lights is going out, then it's probably not the fuse panel wire issue.
