* * * * GM Recall does include C6s (MERGED) * * * *
http://finance.yahoo.com/news/gm-rec...132211510.html
http://syracusecorvetteclub.tripod.com/id168.html http://wemakeitsafer.com/vehicle-rec...Recall-1988598 The second and third link explains the recall. |
I think that recall only applies to the C5 since the C6 doesn't have a key ignition.
Read the second link I just added.
I missed it. What exactly was the C6 recall?
Originally Posted by Boomer111
(Post 1586904011)
(Post 1586904011)
Here are more details:
Originally Posted by GM Press Release
The second safety recall covers 111,889 Chevrolet Corvettes from the 2005-2007 model years for potential loss of low-beam headlamp operation Models from 2008-2013 will be covered under a Customer Satisfaction Program. All repairs will be at no cost to customers.
When the engine is warm, the underhood electrical center housing could expand, causing the headlamp low-beam relay control circuit wire to bend slightly. After the wire is repeatedly bent, it can fracture and separate. When this occurs, the low-beam headlamps will not illuminate. As the housing cools and contracts, the low-beam headlamp function may return. This condition does not affect the high-beam headlamps, marker lamps, turn signals, daytime running lamps or fog lamps. Loss of low beam headlamps when they are required could reduce the driver’s visibility, increasing the risk of a crash. Steven |
There is conflicting information, one source label's the rear lid hinges as being faulty ( weak ) and the other is about the headlamps going out.
Not really sure which is the most recent. |
(Post 1586904109)
Not really sure which is the most recent. Steven |
Got it.
So the engine bay fuse box is susceptible to heat damage. Might be time to get some heat shield on this unit to avoid problems. |
Saw several write ups on the forum a few months ago when I was researching my one headlight going out. For me, that was only a bad bulb, but I read several threads on here about the fuse box wire issue where both lights just go off. Several folks have had fuse block under the hood replaced by dealers, or had a workaround where they added their own wire to fix it. I'm sure someone will post the other links. Wouldn't want to be cruising down the road at night, and pop, the headlights go out.
It's been a know problem or potential issue for quite some time, and took quite a while for a recall. |
Some real heat generated in that engine bay :yesnod:
(Post 1586904159)
Got it.
There's a real good thread somewhere here on the forum about the fuse box issue with pictures. I have not had the problem but did see the thread one time when I was perusing. Sorry, don't remember where it was though, so you'll have to search if interested.
Only 2009-2013 will be fixed at no cost not 2005-2007? |
My biggest concern is I don't want them working on my car. :ack:
Fuse Box
I just had my 2005 fuse box replaced because of the faulty position in the engine bay. I set up a complaint form with GM and discovered I was not alone- if you look online there have been various owners of 2005 vettes who have experienced the same thing like - my headlight going off suddenly after a bump in the road then coming back on. So far GM wont reimburse the 300 bucks for the box. Oh well 72000 miles Why Should I Worry?:cheers:
Originally Posted by arcticblast
(Post 1586904018)
2005, 2006, 2008, 2011, 2012, and Z06 with no model years specified. |
I have a 13 GS, if fuse box is affected. I'd rather fix myself. Wondering if Heat wrap does work
Originally Posted by Cybernetic Medic
(Post 1586904976)
http://news.msn.com/us/gm-recalls-27...on-record-pace
— Nearly 112,000 Chevy Corvettes from 2005 through 2007 because they can lose low-beam headlights. GM says when the engine is warm, an electrical housing can expand and bend a wire, causing it to fracture. GM will also repair Corvettes from 2008 through 2013 if owners have the problem. |
